Originally posted by equinox Hey no problem Larry. I'm in Electronics and only an amature photographer, so you probably know more about the photography side of things than I do. I get what you are saying about capturing light. Do keep in mind that Pentax has Samsung on their side and they can design electronic logic boards with the best in the industry. If Pentax uses faster components to convert and reproduce the images I believe this speed factor you are mentioning may be a wash. (And that is a big if) Just the fact that they are using DDR2 memory and had multiple main board designs tell me they are working to integrate the fastest/most accurate combination possible.
From the Pentax video, the rep shot off 9 straight RAW images which totally blew me away. This is important to me as I like action shots with birds etc. My only problem is my nature lens is going to be a very slow ride on the new camera at f6.7 500mm. Outside of the shooting speed, I know the K100D would be perfect for me. I am trying to justify buying both cameras, and from what I have seen off of the K100D it is impossible to not take a serious look at it.
-Jeff
Hey Jeff, you said you have an Electronics background, so what is your take on the 22 bit A/D converter in the new K10D? What does that mean? I think JPEG only has 8 bits of color per channel and RAW has more (12 or 14 I don't remember) but how does 22 bit help then?
