12-31-2009, 09:56 AM   #136
Risky?????
12-31-2009, 10:58 AM   #137
I don't see any risk in it -- you can always set things back the way they were if you don't like the end results. The biggest problem is that it is one setting for the camera -- not for indivicual lenses.
03-06-2010, 09:40 AM   #138
QuoteOriginally posted by Danny Delcambre Quote
Risky?????
It's not risky at all. I have used it several times. But there is a safer and os-agnostic way of doing it using just a text file! You don't even need this program. I got this from the Pentax Hack homepage, but I have written a short sum up on my own blog. Quite easy and also works for the Mac or Linux or even DOS
03-17-2010, 09:09 AM   #139
Tall Guy's Avatar
Control Software and USB cable.
I just wanted to post an update to the original debug "solution" using the debug software (GX10-K10 Debug Control software / english version)
I have a K10D (1.30) which came down with the back focus illness.
I downloaded the software, I am running Windows 7 (x64).
I ran exe. from the file folder and was able to turn the debug feature on, then Menu / Setup / ^ / AF Test / > / Set / OK.
When proper focusing was attained (Yvon Bourque - AF adjustment chart) reversed the connection process and was able to turn the debug feature off.
Amazing difference!
Note: In Windows 7 I had to run XP compatibility as administrator.
03-17-2010, 09:58 AM   #140
QuoteOriginally posted by Tall Guy Quote
Amazing difference!
This font is very hard to read.
I would like to try this in my K10D to adjust the BF problem using my sigma lens. The K20D is fine with the same lens.
03-17-2010, 01:03 PM   #141
Tall Guy's Avatar
jjdgti
Sorry about the font size.
I have tried a friends K20 with my assortment of lenses, one is a Sigma (10-20) as well, and they performed well on that camera with no menu adjustment.
It was nice to have those images to compare my K10 results against.
I would try this process on your K10 as you have the K20 to compare to as well.
03-18-2010, 07:22 AM   #142
You don't need the software or the usb-cable. The whole deal with the extra program just adds an extra layer of complexity. Refer to the previous posts on how to enable and disable DEBUG_MODE on the fly. Newcomers should be directed to the "new" info - a lot more flexible!
I made a guide on how to do it, btw.
03-18-2010, 08:35 AM   #143
Thanks fatso83 for the link.
03-18-2010, 12:23 PM   #144
Tall Guy's Avatar
Fatso83
I agree, and I will be trying this process as well / in stead of. The ability to have a "field adjust" is a bonus.
03-18-2010, 01:41 PM   #145
lavascript's Avatar
By the way, the easiest way to make the file in any version of Windows is go to to the command prompt and type:
ECHO [OPEN_DEBUG_MODE]>E:\MODSET.TXT
(Change the drive letter to point to your SD card...) That command will put the line in the text file, follow it with a CR and use the correct encoding.
03-19-2010, 02:02 AM   #146
QuoteOriginally posted by lavascript Quote
True, but most people freak out when they see "dos" (as they call it). It's definitively faster, though
03-19-2010, 09:34 AM   #147
lavascript's Avatar
Good point... howabout this?
Start, Run, and copy/paste this:
cmd /c echo [OPEN_DEBUG_MODE]>E:\MODSET.TXT
But change E to your SD card drive letter.
06-12-2010, 07:21 AM   #148
QuoteOriginally posted by tomtor Quote
The adjustment on the K10D is for the body and it effects all lenses. For the K20D it is for the same-model lens, it uses the transmitted lens-id which is also stored in EXIF information.
I adjusted my K10: first at +70 for my FA77, now at +100 because my 18-250 needed a bit more. The good news is that eg my Tokina 400 did focus correctly and still does, so it does effect each lens in a different way.
It is highly likely that if you discover backfocussing with a lens, others are also backfocussing, but that you didn't notice it. An Fa77/1.8 will show focus problems much more clearly than a 12-24 or 18-55 kit lens, because of the very shallow depth-of-field of the 77.
HI,
Where and how do you find these numbers you keep referring to ?? +80, +100 ....
I want to adjust the focus since I already managed to download "debug" on my camera but dont know how to proceed.
By the way, so it seems the camera is now operating with two versions - the 1.3 and the 1.10 - how does this work ?
Thanks for your help
M
10-01-2010, 01:48 PM   #149
pdxbmw's Avatar
once you have enabled the debug mode, hit the menu button, proceed to set up and hit up.
camera, debug, debug mode, dslr, forum, k10d, k10d firmware, pentax, photography, program, usb
K10D focus adjustment with debug mode cem.kumuk Pentax DSLR Discussion 12 01-16-2016 07:11 PM
AF Area Test in K10D Debug Mode mcjm78 Pentax DSLR Discussion 11 02-07-2011 09:57 AM
Anyone use K10D at debug mode? rosier19 Pentax DSLR Discussion 25 12-18-2010 07:34 PM
K10D debug mode and 35 Limited macro treebeard Pentax DSLR Discussion 10 10-21-2009 08:47 PM
K10D doesn't trigger shutter after debug mode Marcoz Pentax DSLR Discussion 7 02-18-2009 11:27 AM
All times are GMT -7. The time now is 09:15 PM. | See also: NikonForums.com, part of our network of photo forums!
