09-18-2009, 05:14 AM   #106
treebeard's Avatar
Thanks. I am going out today to see if it actually works.
**I went outside to take some shots and the AF adjustment seems to work....but I think I need to fine tune it. I can still get the camera to take a shot even though what I am focusing on is clearly not in focus when looking through the viewfinder. Frustrating for sure.
09-21-2009, 07:18 PM   #107
builttospill's Avatar
I'm thinking of downloading the debug mode firmware to adjust my AF, but before I do I need to know if the hacked version will run my SDM only DA 17-70 as firmware prior to 1.3 won't do SDM focusing. Anyone know? Thanks.
09-21-2009, 07:57 PM   #108
Wait, nevermind my last question. This debug mode software is not a hacked firmware, correct? It's just a way into the camera's debug mode. I missed that earlier.
09-22-2009, 01:37 AM   #109
Correct builttospill. You just go on and adjust the settings.
11-03-2009, 11:03 PM   #110
aka
Strangely, the english version of the debug mode program seems to have stopped working. I installed a newly downloaded version on a new laptop and the shortcut reports it can't find the program. Next I went back to the computer I had previously installed it on and saw the same error (it worked a few weeks ago). Finally, I installed the russian-language version and it worked flawlessly. It seems the person that translated it to English was having a little fun and made it delete itself on 11/01 or something, assuming this isn't some anomaly around me. Has it disappeared on anybody else?
11-11-2009, 05:54 AM   #111
baldrick's Avatar
Just a quick thank you to everyone who posted in this thread. After reading this a number times I finally decided to download Yvon Bourque`s test chart and found that all the lenses I use had back focus problems to some extent, so I upgraded firmware from v.1 to v.1.10 and followed the instructions you kind people provided.
The results are as some one else said earlier quite startling especially my 16-45 which I had thought was just a reasonable lens. After some test shots in the back yard of various flowers and Bees I am beginning to see why so many people on this forum rave about this lens - the difference in sharpness is unbelievable.
Thank you so much................Simmo.
Last edited by baldrick; 11-11-2009 at 05:55 AM. Reason: fat fingers = crap typing
11-16-2009, 02:03 PM   #112
pdxbmw's Avatar
I must be doing something wrong, because when I downloaded the Russian debug program, it restarts my computer whenever I I try to go into debug mode.
11-16-2009, 02:20 PM   #113
aka
QuoteOriginally posted by pdxbmw Quote
People running vista have had problems with it.
11-16-2009, 04:42 PM   #114
If you have access to a computer with XP, try that, because it was the only way that I could get it to work (have an ancient computer in my basement that I just use for word processing).
11-16-2009, 05:01 PM   #115
Class A's Avatar
Instead of using the program, you could try this alternative way of enabling the debug mode.
11-16-2009, 05:50 PM   #116
Andi Lo's Avatar
Seems like most K10ds develop some degree of BF as it ages.... Mine was bought used and came with -50 BF on the debug mode.
Thank God for the Russians!
11-16-2009, 07:00 PM   #117
bogiesbad's Avatar
Help an ignoramus please
I need some guidance on the de-bug file...I think I know what to do but am afraid to screw things up.
As I understand:
1. Take a freshly formatted SD card
2. Create a folder named MODSET.TXT (I have K10 w/1.30)
3.Type the command [DEBUG_MODE EN] using notepad and save to MODSET.TXT folder on card.
4.Put card in camera
5.Turn camera on with MENU button pressed (or same with DELETE button).
This should allow me to selct De-bug menu in camera and to make AF adjustments and the de-bug menu will stay enabled without the card in the camera.
To disable follow the same procedure with the disable command in the file on the card.
Thanks for any help here.
chris
11-16-2009, 08:15 PM   #118
aka
QuoteOriginally posted by bogiesbad Quote
As I understand:
Perhaps this is what you mean anyway but:
1. Open notepad
2. type "[DEBUG_MODE EN]"
3. Save file as "MODSDET.TXT" on your memory card (not in a folder)
4. Turn camera on with card in camera and menu button held down.
11-16-2009, 09:19 PM   #119
bogiesbad's Avatar
QuoteOriginally posted by aka Quote
1. Open notepad
Thank you very much. I would have made a folder not named the file....
11-20-2009, 08:25 PM   #120
pdxbmw's Avatar
neither the debug program nor the modset.txt on an SD card is getting me into my K10D with 1.3. Any ideas?
camera, debug, debug mode, dslr, forum, k10d, k10d firmware, pentax, photography, program, usb
K10D focus adjustment with debug mode cem.kumuk Pentax DSLR Discussion 12 01-16-2016 07:11 PM
AF Area Test in K10D Debug Mode mcjm78 Pentax DSLR Discussion 11 02-07-2011 09:57 AM
Anyone use K10D at debug mode? rosier19 Pentax DSLR Discussion 25 12-18-2010 07:34 PM
K10D debug mode and 35 Limited macro treebeard Pentax DSLR Discussion 10 10-21-2009 08:47 PM
K10D doesn't trigger shutter after debug mode Marcoz Pentax DSLR Discussion 7 02-18-2009 11:27 AM
All times are GMT -7. The time now is 03:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
