08-21-2014, 02:15 PM   #1
jeffkrol's Avatar
K200d sudden battery issue
I use this at work for basic product shots. Had it a few years but only up to a few 1000 shots..
Today it decided it no longer likes AA Alk. batteries.. I know not the best choice but it has worked fine for a few years this way.. Now a new set shows bat at 1/2 and soon "exhausts" and shuts down. Sometimes I can restart it sometimes not.. Seems more than a bat issue. Common problem or not??
Focus indicator gets wonky as well. working some times and not others.. Not sure if this is bat related or not. Camera has never seen the "elements"..
Thought of getting a set of Li-ion but it seems more of a problem than this..
Oh checked the contacts as well.. seem clean
08-21-2014, 03:02 PM   #2
kdf9511's Avatar
I have that same issue with my *istD. I went to a set of rechargable Enegizers and that has seemed to clear that issue. Sometimes when you turn it on I have to go all the way to the DOF then back to on and it comes right up. My K200D doesn't like Alk batteries either. I've been using either the rechargables, Enegizer, Eneloops and some others with no issue. Right now I have a set of Lithium AA's in there that are doing just great.
08-21-2014, 09:43 PM   #3
old4570's Avatar
Yeah , my iSTD would not even fire up on Alkalines or Lithium ..
Popped in a set of Nimh , and ran sweet as could be ..
Yeah , iSTD - K200D have battery issues , my first K200D died for no apparent reason .. I took out the batteries to recharge them and when it came to restart the camera = No Go !
It never fired up again , after a little research , seems the breed ( AA cameras ) has serious battery issues ..
I liked the first K200D so much , when a second low mileage camera became available , I snapped it up .
That K200D is on its second battery recharge since buying it earlier this year . ( Has fact original battery grip )
Got to love LSD nimh batteries
08-22-2014, 01:43 AM   #4
iSTD sounds something you get from apple and it leaves with penicilin.
I thought I lost my Ist DL for good but new set of NiMH batteries (Eneloops) and cleaning the contact gave it a life. I also got K100D dirt cheap and did same thing.
Still occasionally the camera turns off and needs to be rebooted even if the batteries are full. Mostly after agressive shoting.
08-22-2014, 08:20 AM   #5
old4570's Avatar
istD , istDL , istDS ....
I have owned the istD , and the istDS
08-22-2014, 10:14 AM   #6
jeffkrol's Avatar
FOLLOWUP:
After getting a set of NiMH to try and digging through the trash.. apparently I had used a AA Lithiums NOT AA alkaline before..
Opps...talk about embarrassing.
Back on track. It really does hate "normal" AA's..
bat, camera, dslr, issue, k200d sudden battery, photography
K200D Battery Issue - Upgrade to K-50? SKYoung Pentax K-30 & K-50 3 06-24-2014 08:28 PM
k3 select battery issue. alarwiida Troubleshooting and Beginner Help 13 06-14-2014 12:30 PM
K200d Battery Door, No Power stand alone, But works with Battery grip pento57mm Troubleshooting and Beginner Help 10 08-18-2013 11:24 AM
K5 IIs Battery charger Issue chrisan Troubleshooting and Beginner Help 4 08-06-2013 05:30 AM
Flash battery life issue CWyatt Troubleshooting and Beginner Help 2 10-19-2012 04:18 AM
All times are GMT -7. The time now is 11:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
