Originally posted by AldaCZ I got this idea along time ago - If a lens has an ID why not to have a settings with them...(if it could be saved into a lens for use with other body...
) I know..keep dreaming
I was thinking more like the body saved maybe 10-15 in a menu and you could go to the menu and select the lens you are going to use, but that's even better, the camera selects the correct setup when the lens is attached and the camera is turned on based on the lens ID and the settings you have saved for it.
