05-10-2008, 01:42 PM   #1
simons-photography's Avatar
battery charger
I'm thinking of getting a battery charger to charge my camera batter "on the go" from a car or a 12 V battery, all I found is this: Amazon.co.uk: BRAND NEW AC+DC/HOME+CAR BATTERY CHARGER FOR PENTAX OPTIO CAMERA MODEL S T20 WP: Electronics & Photo
which is for a pentax optio s t20 is that tyhe same battery as the k10D ?
05-10-2008, 04:14 PM   #2
I tend to just use a power inverter and plug in my regular wall-chargers (I have two). The charger doesn't draw all that much wattage and I can use the inverter to charge other items - like my laptop which i use for review.
05-10-2008, 04:23 PM   #3
Lloydy's Avatar
Yes, go for an inverter. That way you can recharge all your gear like phones and laptops. Get a big inverter and you can boil a kettle for a brew as well!
Try Maplins, they have a decent range.
Maplin > 600W DC 12 V to AC 240 V Power Invertor
I use one of these and run my Cpap machine on it when I'm camping.
05-10-2008, 04:28 PM   #4
I have a 1200W inverter in the van and I can even run a full size printer out of it (it helps having two batteries on the van), so, I would also suggest you get an inverter. Beside, they likely are cheaper than the battery charger itself and you might get more use out of it.
05-10-2008, 11:27 PM   #5
ok thanks for the suggestion I'm aware of inverters could somebody answer my original question though the portable charger is 10 rthe inverter is 35 and I'm not slinging an inverter over my shoulder thanks
05-10-2008, 11:36 PM   #6
PentaxPoke's Avatar
Why would you sling the inverter over your shoulder? It would be in the car!
05-11-2008, 12:11 AM   #7
well I was thinking very long walks but perhaps a spare camera battery or two would be best there. in anycase you are suggesting I buy an inverter just so I can plug in a small battery charger it would be a waste of equipment and a very ineficient way of converting power up to 240 volts and back down to 8, its much simpler to plug in a 12 volt charger to the car or other 12 battery in the event I am mobile in some other way why do I need another peice of totally unecesary equipment ? and again the original question still remains is that charger I linked to suitable for the battery of the K10D
05-11-2008, 02:23 AM   #8
gowerray's Avatar
AC/DC charger
Had a quick look for you on 7Dayshop and came across this little beauty USB/Mains/Car I've had no problems with 7Dayshop at all. Price, delivery and quality, all good. There are other types on there as well. Didn't search for the K10 battery type but for AA or AAA the one linked seems ok.
Hope it helps, Ray
PS Here's the one for the K10 (need a battery plate, also available from 7day) K10 charger
05-11-2008, 03:29 AM   #9
QuoteOriginally posted by gowerray Quote
Hope it helps, Ray
thanks thats just what I need it looks to be the same as the one on amazon and cheaper but the different plates are highlighted as you buy the universal charger and the compatible plate
05-11-2008, 05:15 PM   #10
The batteries used in the Optios are TOTALLY different from the K10D/K20D battery. The DSLR batteries couldn't possibly even fit in any Optio!
So a charger for Optio batteries is not going to work.
05-12-2008, 09:59 AM   #11
QuoteOriginally posted by Entropy Quote
ok thanks for that
battery, camera, car, charger, dslr, optio, pentax, photography, t20
what battery/charger are you using for K-X? blu3ness Pentax DSLR Discussion 18 12-12-2009 08:43 PM
12 volt battery charger for K7 battery stuskier Pentax DSLR Discussion 4 11-22-2009 10:16 AM
For Sale - Sold: Pentax Battery Charger D-BC50 + NP400 L-ION Battery happicamper Sold Items 1 10-05-2008 05:25 PM
WANTED: Backup K10D battery charger & battery. jacksonpritt Pentax Camera and Field Accessories 3 08-29-2008 09:33 PM
Better Battery Charger? Venturi Pentax Camera and Field Accessories 6 07-18-2008 08:16 AM
All times are GMT -7. The time now is 01:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
