Quote: Also, when your pc goes wrong, there is always a brother or a friend that knows his way around windows to fix stuff for you. As for mac users it's hard to find someone that can fix your mac.... what do you do? Go to the apple store witch means more cost again.
My first advice to him would be to never listen to Mac fan boys and do the real homework of what he needs.
Now to your personal issues. Mac pros are very cute, but not very flexible and VERY expensive. the upgrades are almost non possible. Can I add a second graphic card? Can I add anything else? How many PCIe slots? Can I even add an internal HDD or SSD?
Depend on your family or friends when something goes wrong to fix your PC? Ya, great strategy.
Do real homework? i.e.. Become a computer geek. I used to program machine code, no thanks been there done that, it's work.
And why are you asking me what you can do with Mac Pros? You're supposed to be the expert.
The problem with your whole dissertation is, my school board did actual research on the issue, and decided that MACs were cheaper to run. Now there were guys in the AV department arguing exactly the way you are, and in the end. They lost. The PC required 10 times the support the MACs did. Not exaggerating here, those were the numbers. I'm not exactly lacking in knowledge here. I built my own PCs for class room use. And then maintained them. I know the rigamarole inside and out.
My advice is, unless you are a computer geek, and actually enjoy working on your machines, or can't afford it, buy a MAC.
As for your un-affordablity, when I've was in the stores, I've seen companies walk in and buy 5 Mac Pros in one sitting and leave with fully configured workstations. Affordability is a relative term. I argued successfully from the numbers where I worked , that we couldn't afford PCs, using real hard numbers from real research, an won, based on the numbers. And as for the 10% market share, well you can buy market share, or you can buy customer satisfaction. When you go for the customer satisfaction thing, you aren't talking about computing power and specs... you're talking about "how good does this thing work."
But long story short, I probably have as much history in computing as you do, and I completely disagree with your analysis. And I would suggest recommending that our family or friends maintain your machines is completely unprofessional. But then, I worked and made these kinds of decision in a professional environment, where actual facts, not silly opinions ruled the day.
