05-12-2008, 02:55 PM   #1
HDR Time Lapse and the K10D
Hello all,
I have been successfully using my K10D for shooting HDR panoramas for a couple of months now. After some workflow adjustments to get the process as efficient as it can be, I am now pretty happy with things. My next experimentation is to be HDR time lapse.
However, I have been 'playing' with Remote Assistant v3 for a couple of days now and while it is okay software, it has a few limitations. First, it appears you can take only 99 shots (can't do much serious time lapse with only 99 shots at 5- or 10-second intervals). Secondly, and very importantly, there does not seem to be a way to trigger the shutter and hold it for the full duration necessary to fire the bracketed HDR sequence. What I need is to have the full 3- or 5-exposure BRACKET fire at specificed intervals, not each exposure (if you have played with Remote Assistant, you know what I am talking about here).
I have seen in the forum that within the K20D, there is reference to a setting under the 'Custom' menu that allows the full bracket to be fired with only a momentary tap of the shutter button. Can anyone confirm that it is possible to fire a complete 3- or 5-exposure bracket at timed intervals with a single shutter click (and not via 'holding down' the shutter for the full bracket)? Is there any chance the next version of K10D firmware (v1.30 is the one I am using) might add this ability, if it exists currently in the K20D?
If this doesn't work, I am thinking of using Remote Assistant to do everything BUT trip the shutter. For the shutter trip, I can hack a timer through my USB port to plug into the shutter cable socket and my PC and write a little VB program to trip and hold the shutter for the bracket duration at specified time intervals (which would fix both issues mentioned above), but I figured surely someone else must have run across this and found a solution. I don't see a need to re-invent the wheel if someone else already has :-)
Anyone? Help would be greatly appreciated!
05-12-2008, 03:15 PM   #2
Arduino (or Boarduino)+ 2.5mm stereo plug
05-12-2008, 03:16 PM   #3
AlexM's Avatar
The K20D can fire 3 or 5 shot bracketed shots with a single keypress without having to hold the shutter button down. I use it all the time when I shoot HDR. It makes things much easier than trying to hold the shutter button down and counting the shots.
The K200D also has this feature but is limited to 3 bracketed shots with a single keypress. (Page 124 of the K200D user manual).
Personally I don't think that Pentax is going to be adding any new features to the K10D with any firmware updates. It doesn't make any marketing sense to do so.
Alex
07-17-2008, 07:08 AM   #4
K20 hdr
Just bought the K20 and can't seem to find in the manual how to take a HDR shot. Can any one help me on this one?
07-17-2008, 10:47 AM   #5
QuoteOriginally posted by ticats Quote
I do not have K20D and I am not an expert, but I think there is no special feature for taking HDR picture. You just simply bracket to have one overexposed picture, one underexposed and one "sort of in the middle". Then you can use Photoshop to merge them into HDR picture. Correct me if I am wrong please.
07-17-2008, 11:48 AM   #6
sewebster's Avatar
QuoteOriginally posted by AlexM Quote
Alex
I have the K200D and you have to hold the shutter button down to get it to take the 3 auto-bracket shots. If you release, it sets the exposure to the next bracket setting but you have to press the shutter again to take the shot (if you don't eventually it times out and sets the exposure back to "normal"). This is basically what it says in the manual (p126). There isn't a custom setting to change this behaviour.
The K20D manual says that there is a custom option to enable "one push bracketing" (bottom of p130).
07-18-2008, 08:47 PM   #7
Thanks for the info. I will give it a try.
07-20-2008, 12:38 AM   #8
gamgee's Avatar
Nip, could you post your workflow for HDR panoramas?
I wanted to try and get maximum quality HDR panoramas by shooting in RAW but have trouble finding software that can stitch all that together without converting to TIFF 8-bit.
07-20-2008, 01:31 AM   #9
QuoteOriginally posted by nip2655 Quote
I don't think the K20D will do what you want by itself. First, the built in interval shooting has the same 99 image limit. Second, although the K20D does allow one-press bracketing and it works well, bracketing is disabled in the interval shooting mode (I just tried it).
I'd probably get a K20D, configure it for one-touch bracketing, then use a remote timer (I think the Canon TC80N3 and several others should work) I haven't tried it this setup, but the one touch bracketing works fine with the wireless remote control, so I assume it will also work with a wired one.
I'd love to see some of your HDR time lapses when they're done.
07-20-2008, 01:35 AM   #10
QuoteOriginally posted by gamgee Quote
you might check out AutoPano Pro by Kolor. Their website seems to be down for me right now, but I think it is supposed to be able to do HDR stitching. I think it works with raw files too.
07-20-2008, 04:29 AM   #11
gamgee's Avatar
Thanks, that's what I'm using or trying to use, but it does not work on my latest try. It seems that panorama consisting from sky (no clouds) and sea is a bit too much for the stitching algoritm since it can't find the connection anchors on few places in the panorama (yes there is quite large overlap, I checked).
09-21-2008, 10:25 AM   #12
I've been generating HDR timelapse for about a year and a half now. Just wondered over into the Pentax line lately because of the 5 bracket +/-4eV feature (quite unique actually..)
HDR Timelapse - High Dynamic Range Video
MILapse's videos on Vimeo
assistant, bracket, camera, dslr, fire, hdr, intervals, k10d, lapse, photography, shutter, time, trip
TIME LAPSE on K7 leadguitarest Video and Pentax HDSLRs 29 06-01-2011 09:40 AM
Time-lapse with a K10D pxjunkie Pentax DSLR Discussion 12 08-31-2010 10:32 AM
Time Lapse Photography with the K10d rimofheaven Pentax Camera and Field Accessories 10 12-29-2009 01:58 PM
K10D does time-lapse pop4 Post Your Photos! 5 04-24-2009 01:46 AM
K10D and Time Lapse Photography konraDarnok Pentax DSLR Discussion 15 08-23-2007 11:39 PM
All times are GMT -7. The time now is 09:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
