09-14-2014, 01:02 AM   #1
screwdriver222's Avatar
K3, K5II spot af
I have a K3 and generally use spot af, the centre spot and recompose. Now the K3 has 3 af spot sensors for fast f2.8 lenses & K5II has has one.
So the questions begs itself if these af sensors are best for the faster lenses then are the other af sensors best for slower lenses or is there no difference.
Whats your views or experience?
Regards
Jeff
09-14-2014, 02:45 AM   #2
With fast lenses, the 3 center ones should be more accurate in theory. With slower lenses there's no benefit but also no drawbacks to using the center points.
09-14-2014, 09:29 AM   #3
QuoteOriginally posted by screwdriver222 Quote
If Pentax followed the convention of other makers (e.g. Canon), the f/2.8 sensors should be dual with f/5.6 meaning that there is no black-out* with slower lenses. The remaining f/5.6 sensors work equally well with both slower and faster glass, though they will become inoperative if the mounted lens is slow enough. I have no idea when that point would be reached, though I think it is a good guess that there are precious few f/8 AF lenses out there.
* The PDAF system operates on a principle similar to a traditional split-image rangefinder found on many film SLRs and on aftermarket focus screens such as the KatzEye. At narrow apertures the prism refracts the light outside the sensor aperture resulting in no light to the sensor or "black out".
af, camera, dslr, k3, k5ii, lenses, photography, sensors, spot
K5, K5II or K3? Oliver88 Pentax K-5 22 09-23-2014 07:48 AM
Upgrade path: K5II? IIs? K3? ismaelg Pentax DSLR Discussion 7 03-08-2014 04:03 AM
DA 300 AF speed K3 vs K5II Shanti Pentax K-3 7 01-05-2014 11:03 AM
DXOMark - K3, K5II & K5 MarkJerling Pentax K-3 11 12-23-2013 05:06 PM
DA* 55mm f1.4 with K5ii or K3 (AF speed) horc00 Pentax SLR Lens Discussion 9 12-18-2013 11:52 AM
All times are GMT -7. The time now is 11:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
