Originally posted by jonboy And blow out your highlights? No thanks, that's not for me.
jonboy, take a look at the "Expose to the Right" article at Luminous Landscape. The suggestion is that you expose to the right
as far as you can without blowing important highlights. The article explains why you should do this and it's pretty cut and dried. Boils down to this: The way digital sensors work, you capture at LOT more info at the bright (right) end of the histogram. If you're so scared of blowing any highlights at all, you end up getting photos with considerably less dynamic range. Note that I said,
without blowing important highlights. There's nothing wrong with blowing unimportant highlights, and you have to do this all the time - that or lose shadow detail, and often you have no good choice but to do both.
The problem, I find, is that it's really hard to tell what's an important highlight and what's not just by looking at the camera's histogram or even using blinkies (letting the camera tell you what's getting blown). So if I'm shooting outdoors in the sun, and especially if the sky is in the shot anywhere, I almost never get a histogram that's weighted to the right, because if I do, I've usually blown important highlights and can't recover them. SO I find myself often having to expose for the highlights, and then bring the midtones and shadows up in post-processing. And that of course brings in noise. I'd like not to do it this way. I accept the rationale of the expose to the right idea. But in practice, what I really need isn't to push my exposures to the right - I need a camera with greater dynamic range!
Will
