05-13-2008, 02:30 AM   #1
MTF
Hi All,
I am a newcomer. I've searched as best I can but cannot find this. What does MTF stand for and what are the advantages of using it?
I shoot for stereo images and mainly use TV or P.
Jay
05-13-2008, 06:25 AM   #2
joefru's Avatar
Modulation Transfer Function. It's complicated, but the easiest way to think of it is just as sharpness and contrast.
For a full explanaion, see here: MTF
05-13-2008, 06:38 AM   #3
Moderator Emeritus
That might be what it stands for but the feature is this. Each lens has a chip inside and one of the things programed there is the designers selection of the best focal length and f stop combination (zooms) and with a prime the best aperture for that lens to achieve maximum sharpness/contrast. It sends the data to the camera body if that feature is enabled to get the best results.
The issue is that resolution and contrast go hand in hand but too much of one hurts the other. Too much contrast kills resolution and vice versa. So the designers program in the spot where the 2 are as close to the best as possible.
05-13-2008, 06:42 AM   #4
joefru's Avatar
Heh. Just realized that I hadn't mentioned anything about the MTF program line. But you beat me to it.
To the OP: What are stereo images?
05-13-2008, 06:51 AM   #5
OniFactor's Avatar
stereo images are images taken next to each other, with a slight bit of adjustment in the angle of one position, so that using the 'magic eye' technique, you can blend the images into one, and see a "3d" version of it
05-13-2008, 10:52 AM   #6
jlp
QuoteOriginally posted by joefru Quote
. . . What are stereo images?
This is basically the image you would end up with and then, using a 3d image viewer, the image appears multi-dimensional. Sometimes you can 'fake' the viewer by putting something at the picture center junction (e.g., an envelope) and moving your head position fore-aft while un-focusing your eyes to get the 3D affect. Works best for a smaller size picture.
05-13-2008, 12:55 PM   #7
joefru's Avatar
A 3D image viewer? You mean like a ViewMaster?
05-13-2008, 01:21 PM   #8
Big Dave's Avatar
Here is a link for an explanation of the old stero film cameras used to make 3D images.
Dave
Stereo camera - Wikipedia, the free encyclopedia
05-14-2008, 05:13 AM   #9
jlp
Here's an example and how it's done with a point-n-shoot Pentax S4i (as used in the photo above). Read pages 57-59.
http://www.pentaximaging.com/files/manual/OptioS4i%20%20Web%20.pdf
05-14-2008, 09:56 AM   #10
joefru's Avatar
QuoteOriginally posted by jlp Quote
So I was right? That looks just like a ViewMaster.
camera, dslr, mtf, photography
MTF program line overexposes? Adam Pentax DSLR Discussion 12 06-09-2010 12:49 PM
MTF chart garyk Pentax SLR Lens Discussion 4 05-27-2010 06:27 AM
M 50mm MTF charts whojammyflip Pentax SLR Lens Discussion 25 02-14-2010 12:27 AM
any MTF (resolution) data on the 18-55 MKII? Pentaxor Pentax SLR Lens Discussion 2 11-16-2009 12:40 PM
Is there MTF graph of A50/1.2? ogl Pentax SLR Lens Discussion 1 09-16-2009 07:29 PM
All times are GMT -7. The time now is 08:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
