09-27-2014, 11:05 PM - 1 Like   #1
Pentax Hack: MODSET
thought of listing the MODSET nos:
hope to see a full list being created:
K10D with firmware v1.20 -v1.30: MODSET.TXT
GX10 with firmware v1.20-v1.30:MODSET.TXT
K10D with firmware v1.10: MODSET.421
GX10 with firmware v1.10: MODSET.429
K20D: MODSET.442
K20D v1.03:MODSET.442
K200D: MODSET.445
K200D v1.00.00.03 :MODSET.445
GX20 v1.01, v1.03:MODSET.454
Km : MODSET.464
Km v1.10: MODSET.464 press "Delete" during turn-on
K7: MODSET.474
K7 v1.01: MODSET.474
K2000 v1.10: MODSET.482 press "Delete" during turn-on
Kx: MODSET.492
k-5 MODSET.505
how to create a modset file:
open a text file copy the below text
[OPEN_DEBUG_MENU]
save with filename modset.XXX as file name
transfer it to root of SD card, boot debug starts
09-27-2014, 11:43 PM   #2
I don't have time to do an audit, but I don't believe this list is fully accurate. I have a complete set on my other computer, but it is time for bed here.
09-28-2014, 07:03 AM   #3
Pentax K5 Hack : MODSET.505
QuoteOriginally posted by uttam.hathi Quote
K20D: MODSET.442
K200D: MODSET.445
Km : MODSET.464
K7: MODSET.474
Kx: MODSET.492
k-5 MODSET.505
[OPEN_DEBUG_MENU]
thank you very much uttam hathi !
I will try this Debug-Mode on my K-5 very soon !
do you know if there is a way to increase Long-Exposure of Pentax Q, Q7, Q10, etc...
from 30 seconds up to 60 or 120 seconds ?.. or even more ?
3x M27 Dumbbell pics from Pentax Q10 :
www.pentaxforums.com/forums/136-pentax-q/212387-astro-q-club-10.html#post2935714
these ILCs would be " true Killers " in Astrophotography of Small & Tiny objects from Deep-Sky...
their Sony Back-Side-Illuminated CMos sensors are from 1,9 up to 2,8 times more efficient than usual CMos
of course from 1,9 up to 2,8 times more efficient than usual CMos per unity of area !
but the 30 seconds limitation actually forces to set ISO 1600,
which is not the straight way to get the best IQ...
09-28-2014, 07:32 AM   #4
@geo444
I don't know whether a hack could enable it, but I think many of the 3rd party remote timers do offer this possibility.
@uttam.hathi
A complete list should also add information, what to do during switching on.
This is different for the Pentax DSLR series,
For the KM/K2000 you mentioned the pressing of the DELETE button.
For the K200D, the SD card door must be open instead (can be closed immediately after switching on).
09-28-2014, 07:45 AM   #5
@ RKKS08 try 'pk tether' PK_Tether | Tethering and remote control software for Pentax DSLR cameras
---------- Post added 09-28-2014 at 08:18 PM ----------
of course this is the original work Welcome to Pentax Hack just an attempt to aggregate
---------- Post added 09-28-2014 at 08:25 PM ----------
my attempt is to aggregate modset, if any one has any additional to the ones i have may i request to repost with all together so that when one needs it can just look at one place
i will do this periodically of course it will not be audited as i will and may not have all those bodies to test, request if someone test it and works pls do state.
K20D: MODSET.442
K200D: MODSET.445 -the SD card door must be open instead (can be closed immediately after switching on).
K200D v1.00.00.03 :MODSET.445 -the SD card door must be open instead (can be closed immediately after switching on).?
Km : MODSET.464
K7: MODSET.474
Kx: MODSET.492
k-5 MODSET.505
Read more at: https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/274316-pentax-ha...#ixzz3Ece1MFCj
09-28-2014, 08:25 AM   #6
Pentax K-5 Hack : MODSET.505
QuoteOriginally posted by RKKS08 Quote
@geo444
... I think many of the 3rd party remote timers do offer this possibility...
not sure what you mean exactly ?
- Bulb-Mode is also limited to 30 seconds !
- Multi-Exposure Mode outputs a JPEG file, not a RAW
- PKTether doesn't work for Qs... just for DLSRs
- No Remote-Timer control port on Pentax Q, Q10, Q7, Qs1, etc...
- even the IR Remote-Timer doesn't work in Bulb-Mode !
so what ?...
09-28-2014, 08:43 AM   #7
@geo444
Sorry, I read your post not accurately enough, so I guessed you were speaking about your K-5.
And with my K200D and *istDS, exposure time in B setting is only limited by battery status (and maybe overheating of the CCD sensor).
@uttam.hathi
I also have a *istDS, and for this initiating debug is built-in, no need for a modset file.
But starting the debug mode is more complicated:
During switch on, press the AEL-L and INFO buttons at the same time.
After that, you have approximately 5 seconds to press the MENU button twice, then the INFO button.
Voilá!
Edit: You now see the debug menu, the cursor positioned on the first item DEBUG <OFF>. Change it to <ON>.
To cancel debug mode, start the camera the same way, but now confirm the "DEBUG <OFF>".
09-28-2014, 08:53 AM   #8
MD Optofonik's Avatar
QuoteOriginally posted by geo444 Quote
Longer exposure times would be very nice but I wonder about overheating.
09-28-2014, 09:18 AM   #9
QuoteOriginally posted by MD Optofonik Quote
Yes, it would be better to stack.
09-28-2014, 09:35 AM   #10
Longer exposure times would be very nice... but I wonder about overheating.
No Over-Heating during Astrophotography !
only Regulators & Timers at work
these small ILCs are made to shoot Long Movies @ 30 fps in the hot hands of the operator => 40°C
no worry they could reach such High Temperatures shooting Astro-photos !
a night in August, I shot a 10s Auto just after the 30s :
www.pentaxforums.com/forums/136-pentax-q/212387-astro-q-club-10.html#post2939126
... and the internal Camera Temp was...
the same than Ambiant
= 24 °C !
each time, the tiny battery lasted all the night long !
09-28-2014, 10:00 AM   #11
UPDATE 3
*istDS, debug is built-in, no need for a modset file.
procedure: During switch on, press the AEL-L and INFO buttons at the same time.
After that, you have approximately 5 seconds to press the MENU button twice, then the INFO button. Voilá!
Read more at: https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/274316-pentax-ha...#ixzz3Ed8NsBtz
K20D: MODSET.442
Km : MODSET.464
K7: MODSET.474
Kx: MODSET.492
k-5 MODSET.505
Read more at: https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/274316-pentax-ha...#ixzz3Ed8x7NFm
09-28-2014, 06:32 PM   #12
I'm a bit interested in all this stuff. The idea of taking my own photograph of a nebula blows my mind. Is there a primer somewhere; a very step by step, "I am a bear of very little brain.", type primer?
09-28-2014, 06:50 PM   #13
There are a couple of threads on this site. I too have been wanting to give it a try, but have been stymied by clouds and/or super moon as of late.
09-28-2014, 06:52 PM   #14
@ MD Optofonik check this thread
https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/162237-pentax-kx-dfs-success.html
10-09-2014, 01:51 AM   #15
has anyone effectively used frmcrypt.exe as made available at pentax hack download page Downloads , if so what is the procedure.
camera, card, cmos, door, dslr, firmware, k-mount, k7, km, modset, pentax, pentax lens, photography, press, q10, sd, slr lens, text, v1.01, v1.10
Debug Mode and Modset File of the 645D rapptor Pentax Medium Format 6 10-12-2014 08:12 PM
Pentax Firmware Hack site tr13 Pentax DSLR Discussion 433 09-30-2014 08:59 AM
Pentax K-30 Hack? steezylistic Troubleshooting and Beginner Help 6 11-20-2013 02:01 AM
Pentax FW video hack K5 em-tx Video and Pentax HDSLRs 29 09-26-2013 02:42 PM
Pentax Camera Hack johnyeros Pentax DSLR Discussion 7 06-26-2013 12:48 AM
All times are GMT -7. The time now is 01:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
