Originally posted by RonHendriks1966 That is very nicely a little smaller then Olympus'ses micro4/3th sensorsize. Why not use that technology since it's there?
I know this made your image, but with K-01 you would have 3474*1737 pixels, wich is still a good size with 6 megapixel and you can still print a nice image (if you print at all).
I do happen to have a K3, so I use my K3
I have nothing against micro 4/3 but I do not want to buy another camera, an adapter and put my FA77, loose autofocus just for that.
If I replace K3 by a micro 4:3, then if it also 24MP, the situation in term of quality ect that some have is even worse. You loose 1EV, it doesn't cost that much less. Don't know for size...
As for it would have still 2474x1737 pixel available and that more than enough... In theory. If thoses pixels where perfect yes. But it is not, there low pass filter, there interpolation of colors...
The same kind of crop, many time was a bit too much with K5 and started to really show lack of sharpness where it is still ok with K3.
This come you know from the actual resolution you get in practice, not the theoretical resolution. Maybe DxO is not good, but it show it. A lens get 8-9MP effective on their tests with K5, 10-12 with K3. If you count this actual resolution, it not 6MP worth of detail you really get, but 2MP. While the K3 would get 2.5-3MP depending of the lens.
That not much in many case, but as such average resolution the difference will show in prints and from my practical experience on screen too. And I have only a 2MP full HD screen, 4K 8MP screen will soon become the standard.
If you count the effective resolution of 8MP a K5 or K-01 typically give you also found you don't need thoses A1 or 40" shoot to start to see the difference, an A2 20" will already clearly show it without crop, an A4 shoot or a high resolution screen will show it if you crop.
