10-05-2014, 06:10 PM   #1
MadMathMind's Avatar
Why are in-camera JPEGs so huge?
When I process the RAW files in Lightroom and then export them, it's rare an image goes over 8MB. Everything straight from the camera is 9-12 MB. Why is there such a huge disparity?
Noise reduction is obviously a huge difference maker (as mosquito noise crushes JPEG), but I don't apply that to all images. Even clean ones seem to be much, much smaller.
10-05-2014, 06:20 PM   #2
kp0c's Avatar
Good question. Do you export as sRGB? Do you have the jpeg quality slider at 90% (I think it's the default)? Some guesses.
10-05-2014, 06:23 PM   #3
I use Adobe RGB (in Photoshop), not sure what in Lightroom. Quality is set to 100%.
10-05-2014, 06:38 PM   #4
Miguel's Avatar
Perhaps different compression schemes are used by each product? Have you read Jeffrey Friedl's analysis of LR's jpeg exporting capabilities?
M
10-05-2014, 06:48 PM   #5
QuoteOriginally posted by MadMathMind Quote
Some Pentax cameras have **** JPEG quality in addition to ***. Stick to 3 stars if that's the case.
10-06-2014, 04:43 AM   #6
Oldbayrunner's Avatar
Food for thought, usually Pentax camera raw or dng photos are anywhere from 9-14 bits data with zero to very little compression depending on what model of camera one is using, meaning a larger file size. Camera Jpeg mostly are 8 bits of data and smaller than raw to start with. If you are working in Lightroom or photoshop etc. from a raw file using Pro photo RGB, which is one of the widest color gamuts, then converting to jpeg the files have information tossed and compressed into a smaller 8 bit file vs exporting using Tiff or PSD hence a much smaller file size. I do need to mention if your workflow is in 32 or 16 bit color, then your conversion to jpeg tosses some of that color information also reducing it to 8 bit color, however you would not visually notice any difference outside of possible banding.
10-06-2014, 05:21 AM   #7
kp0c's Avatar
Why *** instead of ****? Is there not a difference in image quality?
10-07-2014, 03:57 AM   #8
adwb's Avatar
QuoteOriginally posted by kp0c Quote
Because its more physical size, computer screens compress images to make them fit, if you look in PS at the image and look at actual size and fit screen you will see that , but I think you know that, the point is you can take the lowest MP and star rating and the highest and using fit screen they will look the same , but try actual pixels or ( if you have calibrated correctly) print size then you will see the difference.
10-09-2014, 06:54 PM   #9
In the K-5 series bodies at least, there is ****, but I quickly found that there was little to gain from the lower compression (higher quality) setting, so I just set it at *** for both my K-5 and K-5 IIs. Theoretically, the lower compression ratio of **** should give better IQ, but I found that I couldn't distiguish them after pixel peeping both for about a week's shooting in the field, so after that, I "settled" for the higher compression setting, and have found no reason to change this after shooting both for a couple of years. BTW, I'm primarily a jpeg shooter (birds).
Apparently Pentax engineers felt the same, and on the K-3 set the highest quality jpeg compression back to ***, which I assume is approx. the same compression ratio as the *** on the K-5.
BTW (2) I also tried the ** setting, and immediately noticed jpeg artifacts, so I never use that much compression in the cameras.
Scott
10-09-2014, 07:36 PM   #10
kp0c's Avatar
Thanks for that, nice detailed answer backed up with personal experience. I'll try the *** rating (although I mostly shoot raw, it will help speed up my camera in raw+ mode)
10-22-2014, 09:21 AM   #11
emalvick's Avatar
The other thing that could make a difference is any noise removal you are adding can reduce image size. Noise can add to the file size and reduce the efficiency of the compression ratio.
camera, dslr, in-camera jpegs, noise, photography
Why are M Lenses so cheap! kentishrev Pentax SLR Lens Discussion 27 09-18-2014 06:44 AM
So, why are new pentax lenses so expensive? texandrews Pentax Medium Format 63 08-20-2014 03:13 AM
Why are viewfinders so small today? Penceler Pentax K-5 10 04-19-2014 03:58 PM
Why are camera bags so expensive? 6BQ5 Pentax Camera and Field Accessories 32 11-15-2013 10:19 AM
Why are wide angle primes so expensive? bullitt_60 Pentax SLR Lens Discussion 23 01-26-2013 04:13 PM
All times are GMT -7. The time now is 11:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
