05-15-2008, 06:12 AM   #1
K100d Flash question
I just bought a K100d...YEAH!! but the pop-up flash doesn't work... BOO!
What can I do? What kind of flash will fit the Hot Shoe, (reasonably priced...cheap)or can this be fixed?
Anyone else had this problem? Anyone have an extra flash that they don't need?
Thanks!
05-16-2008, 12:44 AM   #2
nah
Are you sure the flash mode isn't in manual? If you press the flash button on the top left of the body, does the flash pop?
I just recently bought the Metz 48 after reading great reviews about it, and the reviews were right. Great unit.
05-16-2008, 04:16 AM   #3
actually.. I JUST bought it off of ebay and haven't gotten it yet. Probably Monday. But, that's the first thing that I'll check. They just said that it quit working. Wouldn't that be great if that is what's wrong!! I'm so excited to get the camera, I sort of jumped the gun on trying to fix it. Will let you know. Thanks alot!!
05-16-2008, 04:30 AM   #4
ftpaddict's Avatar
If you got it cheap, you could get it serviced. Sometimes it's just the bulb that needs changing.
05-17-2008, 03:32 AM   #5
I hope the on-board flash works - if not, there are a ton of options: First: Pentax flashes: I have 3 AF 360 FGZs. They work well in tandem in P-TTL (I have to use on on-board as a control or master, 2 off camera in wireless). I got one off of ebay (in pretty much mint condition) for $112 including shipping. You have to be patient though. A new one is about $180 last I checked (Amazon Marketplace, B&H, Adorama)
I also picked up some older Sunpaks - camera is in manual flash mode, and the flash is either in thyristor (auto) or manual mode. No P-TTL, but very inexpensive - just make sure the flash trigger voltage is low (<8 volts). The Sunpak 383 is also a very solid flash (new for about $80) but again, no P-TTL.
I heard great things about the Metz flashes. I have never used one.
Hope it helps!
05-20-2008, 05:37 PM   #6
I put the flash on Auto, it pops up, but no "flash". I tried it on Manual, same thing. The flash icon shows in the viewfinder. Is there somewhere I can have it checked, like Ritz Cameras? or will I have to send it off? Should I spend the $$$ or go for the bigger one? And will it work on the hot shoe since the other one doesn't fire?
05-21-2008, 12:57 AM   #7
ftpaddict's Avatar
If you plan on getting creative with your lighting, you might as well invest into a genuine Pentax flash unit. Or at least a Metz.
Try visiting your local camera shop and stick a flash unit on your camera, and test to see if the flash fires. If it does, then your on-board went BOOM.
05-21-2008, 03:54 AM   #8
PentaxPZ's Avatar
If on board is dead, but the shoe works then try changing the flash bulb, gotta be cheaper than an shoe flash...
05-21-2008, 04:21 AM   #9
ftpaddict's Avatar
That was also my train of thought.
05-21-2008, 06:47 PM   #10
I'm going to take it to Ritz Camera and have them look at it. I think you both are right about the blub because everything else seems to work fine... just no "flash". I hope they can put a new one in. Thanks alot for your input.
05-21-2008, 10:21 PM   #11
Check around you might luck out like I did. Went to crags list last Friday and by Tues. morning I'am the broad owiner of a Metz 50 MZ-5 and a 76MZ-5 for 550.00 shipping total. Never seen a cleaner light off a flesh. Lucky A-Hole Me
camera, dslr, flash, k100d flash, photography
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
K10D, K100D flash question WillCarney Pentax DSLR Discussion 2 12-21-2009 12:58 PM
Slow flash - fill in flash - k100d soalle Pentax DSLR Discussion 4 06-21-2008 02:06 PM
Flash Question - Turning Off Flash Quickly For a Shot sweetpapa Pentax DSLR Discussion 5 06-16-2008 12:04 AM
K100D AF assist / flash question rparmar Pentax DSLR Discussion 11 01-28-2008 09:16 PM
All times are GMT -7. The time now is 03:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
