I upgraded from a kx to a k5, and frankly was a little underwhelmed by the difference. The K5 is a better camera, but images are noisier than the Kx, and it's a good thing the viewfinder is better, because the autofocus sucks! It made me realise how far above its weight the kx had been punching! (To be fair to the k50, the k5 is the same generation as the kx, so I would expect some improvement to noise and autofocus over the k5)
I've since had quite a few chances to play with a friends k-3, and frankly the difference between the k-5 and k-3 is staggering. The lack of AA filter makes a significant difference to image quality (and everything else is just better, faster, cleaner).
Having played around with the k-3, my advice would be this: unless you need weather sealing, wait for the price of the ks-1 to drop to something a bit more affordable, then jump on one of those. If you want weather sealing, go for a k50 (or second hand k-5iis).
I had a brief play with the k30, and it is a nicer camera to use than the kx (so you will enjoy owning one), but personally I'd rather sink my money into a k-s1, k-5iis, or k-3. (Just because of the increased image quality over my k-5)
---------- Post added 10-12-14 at 11:52 PM ----------
Originally posted by LightBug Also low light and tungsten light focusing was improved in k30/k50.
Admittedly, that is actually the best thing about the k-5 vs kx (I always used to manually focus the kx in low light). Mind you, it's a shame the k-5 can't back that up with the high ISO performance of the kx.
---------- Post added 10-13-14 at 12:02 AM ----------
Originally posted by ElJamoquio The K-x was able to use AA's IIRC whereas the K-50 can't IIRC.
It can with D-BH109
