Originally posted by mikesbike
Great shot! expression, framing, skin-tone, lighting, exposure- all just great! A fine capture of a beautiful subject.
Thanks Mike! Appreciate the comments!
al
---------- Post added 07-28-21 at 06:20 AM ----------
Originally posted by doroth2
I'm wondering if any of you have had this issue with your k20D. I received it new for Christmas in 2008 (I think). Sometimes the battery pops out of place inside the camera. I have to open the battery door and push it back in and it works fine. I was thinking about selling the camera. Is it worth anything at all anymore? Especially with this issue? Should Just pass it on to my kids to learn on? Thoughts?
Theres a white latch that holds the battery in place and you have to depress it release the battery....I'm wondering if yours is damaged, worn ,or the spring does not work.. The battery should not move if that piece is engaged. If thats the case, you can make a thin spacer with foam or folded electrical tape... put that between the Door and battery and it should lock it all in. In effect you will be relying in the door latch now.
The K20D is still a great camera. It has its limitations like all tech... you just need to remember that when using it. The same tech that made it a great camera when it was released
is still there. I had several of these at one point and I did pass some of them down to my kids to learn on...but not because they were no longer good or worth anything...but because they were good and worth alot as photography tools.
I still have a couple for me.
al
