05-17-2008, 08:26 AM   #1
Picture numbering in a K200d
By default the K200d is set up to save pictures in folders by the date you take the picture. Its starts with IMGP001 and the next day it starts with IMGP001 again. If you change it to save in folder Pentax then it starts with IMGP001 and then keeps adding to it. It never starts over again. Isn't there anyway to get the folders with date to save with a different number every time rather than starting over again?
This really causes problems when you are talking photos from a number of folders and putting them into one, you have to rename them.
Thanks
05-17-2008, 06:47 PM   #2
are you sure?
i've got my k200d set to save files into date folders, and it uses incrementing filenames no matter the date
check the memory setting in the first menu, there is a "file no." option that is probably unchecked
dave
05-17-2008, 07:59 PM   #3
Jewelltrail's Avatar
hmcfly
I do not own a K200d, but on my K20d the file numbering defaults to a new number, sequentially. I imagine the K200d is similar.
In the menu, in the Rec Mode, scroll down until you get to "memory." When you get into memory, scroll down until you get to file number. Turning this "on" will enable sequential numbering (I believe this is the default). If you shut it "off" you will return to the system you are currently using for file numbers.
Best Regards,
Ernest
05-18-2008, 09:25 AM   #4
Thanks for all the answers for what ever reason the file box wasn't checked and it's working fine now.
camera, date, dslr, folders, k200d, photography, picture
K200D broken - Mirror stays up, picture not saved cfraz Pentax DSLR Discussion 3 03-22-2010 08:54 PM
Question: Tips for taking food picture with K200d? senree Pentax DSLR Discussion 4 01-02-2009 10:29 PM
New K200D - Please help. Slow picture release sue Pentax DSLR Discussion 18 12-22-2008 09:36 PM
File numbering simonm Pentax DSLR Discussion 26 03-06-2008 05:42 AM
Pentax K200D ISO 800 picture patrickmedina Pentax News and Rumors 5 02-05-2008 01:01 PM
All times are GMT -7. The time now is 07:29 PM. | See also: NikonForums.com, part of our network of photo forums!
