11-04-2014, 07:59 PM   #16
QuoteOriginally posted by shamer Quote
This is why a 50mm f/1.4 gets darker and darker when you add macro tubes and why a fast telephoto lens needs to be so large.
That's where t stops come in. A "t' measurement of a lens is actually a measurement of the light transmitting properties of a lens. T
I think you are getting the issue of T-stops and close-up corrections mixed up there.
close up corrections ( macro extension tubes or bellows draw) increase the f/- based on the number of focal lengths (s) the object is distant.
For example s = 3 when the object is 300mm distant from a 100mm macro lens
Then f/- is increased by s/(s-1) example 3 /(3-1) = 3/2
So the click f/4 would be actually 4 * 3/2 = 6; the aperture is f/6
This is quite separate from the transmission of light through the glass elements(t-stops)
11-04-2014, 09:30 PM   #17
QuoteOriginally posted by wombat2go Quote
Yep...the nominal f-number is based on the focal length at infinity. For close focus the effective f-number increases proportional to the lens extension. This is a well-known consideration for large format photography where even moderately close focus may require significant exposure compensation.
11-06-2014, 12:56 PM   #18
UncleVanya's Avatar
My impression was that T-stop for complex zooms differed more from the F-stop than for primes. However I realized that I don't have any data on this. I went to DXO to see what I could find and honestly had no idea how to read the data. They only list a single T-Stop for each lens and they don't clarify on the zooms what the F-Stop was, what the focal length of the test was etc. So I'm lost. I saw most primes had a net increase in T-stop of a linear 0.2 to 0.4 so for example an F2.8 lens might show 3.2 T stops. If this is very linear and does not increase in the zooms substantially then I would think we can ignore T-stops - but I'd love some real data - are there any video sites out there with more info?
11-06-2014, 01:13 PM   #19
eddie1960's Avatar
QuoteOriginally posted by bradshea Quote
It's really about matching exposure across different lenses and from different perspectivves. you need the accuracy of a t stop for that (because it does vary from lens to lens within a size even (ie a zeiss 28 will be different than a samyang etc)
We can pretty much ignore it for stills because we meter for the shot not for the ongoing scene and series of shots
aperature size accross, aperture, camera, dslr, iso, lens, photography, pictures
Lenses always stopping down to min aperature. Help. mikemike Pentax K-30 & K-50 12 01-06-2014 05:42 PM
autofocus point & aperature interaction with wide & ultrawide lenses Lititz Pentax DSLR Discussion 4 07-19-2011 05:32 AM
K-r and M series lenses in aperature mode noledoc Pentax DSLR Discussion 11 01-03-2011 08:18 AM
Fixed Aperature Lenses Numb Thumbs Pentax SLR Lens Discussion 6 01-01-2010 12:59 AM
K200D and Lenses without 'A' Aperature - Is there a trick? cputeq Pentax DSLR Discussion 3 05-24-2008 01:40 PM
All times are GMT -7. The time now is 12:42 PM. | See also: NikonForums.com, part of our network of photo forums!
