11-04-2014, 02:35 PM   #1
Mapleleaf-Mick's Avatar
AE-Lock and AF-Lock on the Pentax K-3
Can someone please enlighten me as to what each of these buttons do on my Pentax 3. I am hearing that one should try and use the AF-Lock button instead of pushing the shutter button down half way to focus especially in low light and for moving subjects. What are the advantages if any and how does one use/operate this function. I am really nieve on this subject and would appreciate some good sound advice as to the use of the two buttons.
Thank You for reading my post.
11-04-2014, 02:41 PM   #2
LensBeginner's Avatar
QuoteOriginally posted by Mapleleaf-Mick Quote
AF-Lock locks focus on your current setting (same as keeping the shutter button half-depressed), while AE-lock locks exposure.
What you're probably talking about is called back-button focusing, and it's indeed useful for sports.
It entails using the AF/AE lock button for focusing (Focus ON) instead of the shutter button.
a) In the customisation menu, set the AF button to AF2 to disable AF on half press (thus you won't change your focus when half-pressing: the AF/AE button will be you sole focus trigger)
b) Set the focus switch to "C" (Continuous).
c) In the Info panel, turn off the AF.A.
There's also a thread here:
https://www.pentaxforums.com/forums/172-pentax-k-3/272013-k-3-back-button-focusing.html
Main advantage with this technique is that the camera focuses continuously, and you have no lag when you press the shutter button due to focusing (nor you can change the focus by accident), it just shoots.
11-04-2014, 03:35 PM   #3
It is not really an AF lock as much as it is an AF button that allows you to focus separate from the shutter release. As noted above, it can be used for a number of techniques. The AF button can also be programmed to do other functions.
As for the AE Lock button, it holds the current exposure settings despite a change of framing. The most common use is to meter close in when the subject is back-lit, lock the settings, and then back up to make the actual exposure.
11-04-2014, 03:43 PM - 1 Like   #4
*snip*
I also use it when I know where to meter in a high-contrast situation e.g. sunset or sunlit house with strong shadows, lock those values and then recompose as I like.
ae-lock and af-lock, button, buttons, camera, dslr, pentax, photography
AF/AE lock button Gerrys Troubleshooting and Beginner Help 13 09-25-2014 06:09 AM
AE and AF lock behaviour on K-5 and K-3 compared to K-7 jaeaetee Pentax DSLR Discussion 5 11-28-2013 10:15 AM
K-30 AE/AF Lock Button Moondawg Pentax K-30 & K-50 2 09-19-2013 01:26 PM
Recommendations For a Pentax K Mount Camera w/ AE Lock momus2 Pentax Film SLR Discussion 24 10-19-2010 04:56 PM
K100D link/lock of AE-L and AF atnbirdie Pentax DSLR Discussion 15 03-15-2007 06:06 PM
All times are GMT -7. The time now is 04:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
