Originally posted by kcupp95 I had aperture set to 1.8 and was standing at a reasonable distance away - far enough away to get 2 people in a 50mm shot.
The autofocus absolutely struggled with the photos. I could hear it focusing quite loudly and it would often "whir in and out" and be completely unfocused and would take quite a few goes of changing between auto focus and select point focus and half-pressing the shutter button
- Your aperture setting does not affect the AF, neither does ISO or metering.
- The amount of light and subject contrast will affect the AF performance
The AF system needs something to focus on. A good example would be attempts to focus on a blank wall. In bright light the camera may succeed. In dim light, maybe not. It also does better with an unambiguous target.
Not being there to see exactly what is happening, it is hard to say what the problem is and whether there is a solution. I can offer a few tips:
- Make it easy for the camera to determine the intended focus point.* Switch to single point, center (aka "spot") if the system is hunting.
- Use AF-S unless you are tracking motion
- The AF system does better in good light and less well when the light is dim
- Remember that the camera does not "know" your intended point of focus
I own the DA 50/1.8 and have found the AF performance on my K-3 to be better than average. If you continue to have trouble with this particular lens and the AF works well with other lenses there is the outside chance that the focus mechanism is damaged or otherwise faulty. If you are having problems with all lenses in good light, with an unambiguous target, there may be a problem with the camera.
* When the focus point is set to auto, the system will make its best guess as to what should be in focus. Often enough this is the first point that has enough contrast to acquire focus. When that is ambiguous there may be some lag in the system as attempts are made on multiple points.
