11-05-2014, 03:44 PM   #16
I think simply buying a tilt shift lens would be easier
You have some options, Schneider, Arax, Samyang, and then there are the tilt adapters, too..
The real versions can be costly:P.
But yeah, I wouldn't think a tilting sensor would be so easy or cheap to implement. The nice part about the built in shifting is to me it seems to be 'essentially free' or at least pretty cheap to add in the grand scheme of things, a small bit of software making use of already existing hardware. It's not perfect or as good as the real thing, but it's a dandy little addition that imo adds to the value of a camera.
11-05-2014, 06:43 PM   #17
I have the old Pentax shift lens, which I like, though I think it really comes into its own on 35 mm film bodies, and would certainly like to have the opportunity to experiment with tilt.
11-05-2014, 08:24 PM   #18
I bet we will get that feature - olympus had a 5-axis IS for a while nowand it is technically possible to do a bit of a tilt with that. I think it's a matter of time before it shows up on Pentax.
Perhaps a matter of time for olympus's patent to run out though .
11-09-2014, 04:08 PM - 1 Like   #19
Yup. Can't the 5 axis Olympus system already do it?
I'd want more range from the SR... maybe covering the FF area? Especially for video (if it were activated) that would be pretty awesome.
Pentax also needs to add several bracketing modes. For example:
* Bracketing to increase resolution by moving the sensor very slightly.
* Bracketing to increase color accuracy... think Foveon sensor. Every color should be taken for every pixel.
* Bracketing to widen the image frame. The current method of composition adjustments, even with putting the function on the Fx button, takes forever. I want to be able to activate the feature, press the shutter once and the camera does the rest. If the range of movement covers a FF sensor, you could essentially have a FF Pentax with plenty of MP, but in a smaller, cheaper body with an APS-C sensor.
camera, dslr, front, lens, movements, pentax, pentax with tilt-shift, photography, sensor, steve, view
Who wants a Pentax "Professional" neck strap? panoguy Pentax Camera and Field Accessories 16 11-07-2013 11:09 AM
Pentax K3 with 40 MP via sensor shift troenaas Pentax News and Rumors 129 10-07-2013 09:06 PM
Tilt + Shift Option for Pentax! Scootatheschool1990 Pentax SLR Lens Discussion 9 08-24-2013 11:45 AM
Possible to make a tilt shift lens out of a 50mm on a crop sensor? Abstract Pentax SLR Lens Discussion 10 02-07-2011 03:47 PM
Who Wants a 1.3 Cropped Sensor? benjikan Pentax DSLR Discussion 75 03-01-2007 05:51 AM
All times are GMT -7. The time now is 08:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
