05-18-2008, 02:22 PM   #1
Fl_Gulfer's Avatar
Taking a night shot
I'm still dumb as a rock, early oldtimers.... How do I force my K100D to take a night shot at a faster shutter speed? It stays open too long when I try to shoot shots like the moon and such.
05-18-2008, 02:40 PM   #2
Try to shoot manual. That way, you have control of everything, instead of the other way around.
You can also bring the ISO up. If you want more accurate answers, you should post some photos with EXIF.
05-18-2008, 03:39 PM   #3
morfic's Avatar
Start out in M, moon is just another sunlit object, so use "Sunny 16" as your starting point with M. Have fun.
It stays open long if you meter in matrix or center weighed and the moon or (worse) stars take up a very small area of the whole metered area and the rest is black, it just takes a while to get that scene gray. You could meter the moon with spot meter, but remember it would use too fast a shutter speed since it wants the moon to be gray, like anything else your camera shoots
M + Sunny16 is your best bet.
05-18-2008, 04:23 PM   #4
Wheatfield's Avatar
Shooting manual is your best option. Take a shot, chimp it and adjust as needed.
05-18-2008, 08:38 PM   #5
Fl_Gulfer's Avatar
I was shooting in manual and the shutter stayed open for 10 sec. at least.
05-18-2008, 08:51 PM   #6
morfic's Avatar
IF what you chose was 5 seconds, it would probably take another 5 second dark frame to reduce noise on long exposures, check your Custom Functions.
I just don't see you manually choosing 5 seconds to shoot the moon.
And keep in mind, in M, you are the boss, if you don't like something, you change it.
05-18-2008, 09:01 PM   #7
Mike Cash's Avatar
QuoteOriginally posted by morfic Quote
I recall having read on some site about the "Moony 11" adjunct to the "Sunny 16" rule.
Shutter speed set to same (or near) as ISO gives different apertures to use depending on the phase of the moon.
I believe it was something like f11 for a full moon, f8 for 3/4 moon, f5.6 for a half-moon, etc etc.
05-20-2008, 12:22 PM   #8
Fl_Gulfer's Avatar
You mean the camera won't let me choose a 1/2 a sec shutter speed in a dark setting.
05-20-2008, 01:07 PM   #9
Gooshin's Avatar
QuoteOriginally posted by Fl_Gulfer Quote
when you shoot in manual you tell the camera how long you want the shutter open for
if your shutter was open for 10 seconds, that means you set the camera to stay open for 10 seconds!
remember turning the dial sets one parameter, while holding the EL button + turning the dial will set the other.
if you are using stop-down metering to let the camera choose a shutter speed based on your aperture, and you are getting a slow shutter speed, then either increase your ISO, your Aperture, or both.
if you are maxed out at both, well, then, you are just shooting something that is too damn dark.
05-23-2008, 08:54 PM   #10
Fl_Gulfer's Avatar
Where in the manual does it explain how to do this stuff.?
05-24-2008, 08:51 AM   #11
Under the Manual mode section.
On your top screen, or in the viewfinder, you will see your shutter speed adjustments being made. Do not confuse 10" with 10. 10" is ten seconds, 10 is just 1/10 of a second. Holding the Av button next to your shutter release will allow you to adjust your camera in Manual.
05-24-2008, 03:20 PM   #12
When you go in the Custom Setting of the menus, scroll down to "Auto EV Compensation" and make sure it is "off", otherwise, the camera may think you are making a mistake and correct it on it's own. You never have full control if "Auto EV Compensation" is on.
05-25-2008, 05:17 PM   #13
Arpe's Avatar
Or just stick it in Tv (Time value) mode, that way you directly control the shutter speed, and the camera calculates the required aperture and ISO. May not be correct for every situation though, especially at night.
camera, dslr, night, photography, shot
Taking a shot on the roof of buildings? NecroticSoldier Troubleshooting and Beginner Help 28 03-26-2010 02:40 PM
Streets I like taking late night pics, please rate MikesChevelle Post Your Photos! 6 01-20-2010 02:39 PM
Taking night shots w/ K20D..... UpNorth Pentax DSLR Discussion 21 02-16-2009 05:43 AM
Couldn't resist taking another moon shot! ChipB Post Your Photos! 2 10-17-2008 06:29 AM
Taking cityscapes and some night pics... WILDCHILD Photographic Technique 10 02-20-2008 10:56 AM
All times are GMT -7. The time now is 06:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
