Originally posted by jeffkrol Best analysis of the bright vs natural +2 sharpening comparison.
THANK YOU Bart..................
Bart's Blog Very interesting experiment and analysis. Thanks for the info.
However, and maybe unfortunately, what is said by Bart in his conclusion is exactly what Phil Askey says in his review but *not* what Roland Mabo always says (bright mode will resolve the "edge sharpness" issue).
So, now everything are agreeing so far, this explains also why Imatest shows low LW/PH resolution figures with the K10D for the other tests I have seen.
Actually, to do Fourier transform to see the frequency response is interesting. But Imatest measurement on a set MTF (typically at 50%) is the most direct way to get and intrepret the results. That's what Photodo did carry out extensive tests in this similar way (despite they fixed the test chart spatial frequency first and then measure the MTF instead, and to plot the charts).
Doing the test in "physical" domain would be a more practical approach than in "frequency" domain, I think, just because there is actually not much processing in the frequency domain to be done, I bet (unlike audio signal processing, etc.)
Phil Askey do use eyes to judge where the resolution have arrived, but this will not be wrong neither, as everything is indeed so easy to be judged on the shot chart. And, he posts every resolution chart test shots for us to verify, too.
