Originally posted by pcfranchina a couple new ideas.
option1
Pentax k10 on a straight bracket, 540 mounted in hot shoe. Pocket wizard attached to bracket with optical slave plugged straight into it.
Sounds logical but other people will be firing my lights.
option 2
Pentax k10 with hot shoe adaptor with pocket wizard on it and the f5p cable going to an off shoe adaptor with 540. So the 540 should still be p-ttl right?
In option 1, the 540 is triggering (via optical slave), a Pocket Wizard, which is triggering another Pocket Wizard on your Alien Bee? Since you say you'll have the problem of other people triggering your setup, skip the middle man and leave the Pocket Wizards out of it.
In option 2, if I'm reading it correctly, I'm pretty sure you have one hotshoe too few. All the Pentax TTL cables and shoes just move the dedicated shoe off the camera, they don't give you more connections for non TTL applications. Which leaves us with the question, "How to trigger the Pocket Wizard?".
Originally posted by *isteve Why do you need the 540 in this setup? Just curious as to why you would need a PTTL flash with manual flashes (that wont be registered during the PTTL preflash). Why not just switch it all to manual?
Agreed. The few times I've used the 540 in P-TTL for grip and grin party shots, it consistently underexposes and I end up switching to Auto. I can't imagine getting an accurate and consistent exposure mixing TTL and non-TTL flashes.
