05-20-2008, 07:28 PM   #1
joefru's Avatar
SR with manual zooms
I heard someone mention (may have been the other forum) that for his 70-200-ish manual zooms, he sets the SR to 135mm. Is this effective? So far, I've just been changing the SR as I change the focal length. Obviously, I'm not changing the focal length very often. I've kind of been thinking of it as a bag full of tele primes, where it's a pain to change.
05-20-2008, 07:59 PM   #2
Ole
Ole's Avatar
I'd have thought you should dial in a focal length fairly close to what you use - or disengage SR! Perhaps you could run some experiments and show us the results?
05-20-2008, 10:59 PM   #3
ryan s's Avatar
I turn mine off, unless I absolutely need it for a given focal length.
There have been some reports here that leaving SR on an incorrect focal length will result in blurred images...
05-20-2008, 11:34 PM   #4
Logically, a small compensation is better than no compensation. So as long as you are fairly close to the entered focal length my guess is that is should be beneficial. Also if the entered value isnít spot on, itís probably better to stay on the low side with the entered value.
05-21-2008, 01:55 AM   #5
ftpaddict's Avatar
Whenever I use my 70-200, I always set SR to the minimum focal length. That way I always get at least some compensation.
If you set SR to 135 and use your lens @ 70mm, you'll get overcompensation and end up with even blurrier images!
camera, change, dslr, length, photography, sr
Manual Metering on Pentax DSLRs with Manual and Automatic Lenses Adam Pentax DSLR and Camera Articles 20 01-06-2016 03:38 AM
For Sale - Sold: Some Manual (M) zooms 28-50mm, 40-80mm, 80-200mm jgmankos Sold Items 2 07-25-2010 06:48 PM
Zooms and you pingflood Pentax SLR Lens Discussion 30 03-19-2009 02:02 PM
K100ds and full manual mode w/manual lens dwhopson Pentax DSLR Discussion 10 11-06-2008 10:37 PM
Macro: Handheld, Manual Focus, Manual Stop-Down Mike Cash Post Your Photos! 2 06-19-2008 07:14 AM
All times are GMT -7. The time now is 06:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
