Originally posted by adwb I think you will find the lenses weigh about the same , but the A7 being mirrorless is small and very much lighter. When used with a Pentax 50mm or a zoom it is a much lighter combo than my K5IIs with the same lenses.
The only reason I used the kit lens for the drop box images was like a idiot I left the bag with the lenses behind and had to make do with the K5 and a Sigma 2.8 24-60 and the Sony with its 3.5/5.6 28-70.
If Pentax do produce a FF unless they go mirrorless I am pretty sure it will be as heavy as a K3 / K5 so weight saving will unfortunately happen.
Given the new A7version2 just released apparently has shake reduction the body like pentax the benefit will be obvious to users of legacy glass, yes have to set the aperture manually and yes you have to manually zoom, for me not a big deal I often do that with the Pentax kit anyway.
As to the original posters question a simple search on DXo website will give a decent comparison and till you have tried the A7 focus systems and the ability to get instant zoom to fine tune the focus ( if necessary) ther is no real way to compare the two very different systems.
That appear logical but I honestly checked:
You need longer focal with an FF for the same framing... When you do the comparizon the 24-70 is comparable to 16-50 but the 70-200 f/4 is far worse than 50-135 in size and weight. The A7II you speak off has a weight of K50 so nothing spectacular.
As for primes, I agree with you take 2-3 short focal primes with you and shoot A7, will be just fine... And MF if you don't buy a-mount or want more than what is currently available in FE mount.
This a good for some people, but no silver bullet. In the end, FE lenses are more or less one stop slower than they could be to avoid being too big. The crop factor don't only apply to say good things out of deph of field control and high iso, it come very concretely to say that if you have 1.5 crop factor, you can also get 1.5 time shorter lenses too... Or if you prefer that your FF lenses are 1.5 time bigger, mirrorless or not.
