05-21-2008, 10:13 PM   #16
Peacekeeper's Avatar
I agree, Firefox is so much better that IE, a lot less buggy and more secure. I have the photoME plug in for exif online.
Check and clean your lens/camera body contacts. I had similar issues last year but under exposing.
Try this. I hope you have a tripod hehe
Set up a shot ona tripod and looking down at the top LCD panel in let say, Av Mode, half press the shutter and meter the scene. Then change Mode Dial and repeat process checking metering in different modes without the camera moving. remeber to half press the shutter release to activate the metering.
If it is changing just because you moved the Mode Dial then I would send you camera in for repair.
If it is intermittent, then it could be contacts too.
Hope this helps.
PK
05-21-2008, 11:17 PM   #17
Seafood,
Your posted pictures doesn't have EXIF info at all. Post your pictures with EXIF info intact.
then you'll receive much more helpful answers.
05-22-2008, 07:19 PM   #18
LeoTaylor's Avatar
QuoteOriginally posted by joefru Quote
With FxIF installed, you right-click any image and go to Properties. Alongside the standard info (location, dimensions, ...) you get all the major EXIF stuff. ...
Wow. I searched and found FxIF, installed it, FIREFOX restarted and brought me back to where I left off. Poked around this forum and found pictures with EXIF info intact. The whole process took only a few minutes.
Thank you for the suggestion! I will use this often
05-22-2008, 07:45 PM   #19
morfic's Avatar
Now where everyone uses Fxif, i would wonder if Seafood looked himself on his shots if the exif indicates some EV being used?
auto, camera, dslr, mode, photography, shot
Very first day with DSLR - what am I doing wrong? asdfTT123 Troubleshooting and Beginner Help 11 02-21-2010 09:04 AM
K100ds: best DSLR ever, or greatest DSLR ever? Steve Beswick Pentax DSLR Discussion 71 01-19-2010 02:47 AM
sometimes it is just wrong devisor Post Your Photos! 5 07-24-2009 12:19 PM
What am I doing wrong here ? holdgaj Troubleshooting and Beginner Help 9 04-30-2009 10:40 PM
What's right and what's wrong? dws1117 Photo Critique 2 01-08-2008 09:13 PM
All times are GMT -7. The time now is 10:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
