Originally posted by jshurak The normal filter was actually swapped for an IR filter. Its an IR only camera.
That may explain the problem: the new filter may have irregularities in it (structural or mechanical after cutting and polishing) and light passing through it may show those irregularities, especially POLARIZED light. Have you used polarizing filter? Under some circumstances the sky can be polarized as well showing the same pattern. If the pattern does not show under regular light (like indoors) then it is definitely a filter.
I have participated in several experiments (using lasers or other sources of polarized light) testing structural integrity, stress and load distribution, weak points, etc, and under polarized light most types of glass and plexiglas are showing very similar patterns you are seeing.
