12-08-2014, 03:50 AM   #1
kentishrev's Avatar
Annoying mark on some pictures - help please!
Hi all,
using a K-30 (for around a year now) and have noticed some marks appearing on some photos. Always the same mark, in the same place. But not on all pictures, just some! Makes no difference which lens I'm using, so can't be that.
Would this be a dirty sensor? If so, do I need to get it cleaned professionally? And how come it doesn't appear on every photo?
Some examples follow. See the mark in the top left quadrant.
PENTAX K-30  Photo
PENTAX K-30  Photo
12-08-2014, 04:00 AM - 1 Like   #2
Culture's Avatar
Yes. those are sensor dust. You should be able to clean them with a sensor blower.
You should see your user manual about how to clean the sensor.
You can find some ideas here.
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/271116-l...ning-tips.html
Sensor dust become more pronounce with smaller apertures. That is why you will not see them in all photos
12-08-2014, 04:37 AM - 1 Like   #3
i_trax's Avatar
yes sensor dust, higher F stop , more visible.
you can clean it with a blower, anable sensor cleaning on power on and off on your K-30
12-08-2014, 05:10 AM - 1 Like   #4
Kozlok's Avatar
To find the dust most clearly, take a photo of blue sky at f22 with the lens focused to infinity (use manual focus with the ring turned all the way out). Usually easiest to get only blue sky with a longer focal length.
12-08-2014, 08:32 AM - 1 Like   #5
Just find your sensor cleaning function and blow the dust with a rocket blower then turn the on/off switch to off. Never remove a lens while your camera is on, the static will attract dust into your camera.
12-08-2014, 11:06 AM   #6
kentishrev's Avatar
Thanks all. I've bought a Giotto Rocket Air blaster this afternoon, and am charging up the battery right now. Will attempt to air blow this away later on. As a matter of interest, can anyone explain why this doesn't seem to appear in every picture?
Edited:
I've now blasted some air - and test shots suggest it's gone. Many thanks!
12-08-2014, 09:20 PM   #7
Kozlok's Avatar
It shows most clearly on a solid background at a small (large number) aperture. A pure blue sky is the easiest to see it in.
camera, dslr, mark, photography, pictures
Help me understand some settings on K3 Please Tom777 Troubleshooting and Beginner Help 2 05-24-2014 05:39 AM
Dirt/spots on my pictures :( Please help spectamaniac Troubleshooting and Beginner Help 15 02-06-2013 04:34 PM
Pictures disappeared! please help k100pip Pentax DSLR Discussion 12 11-12-2008 09:05 PM
Help Please...Night Time Skyline Pictures 68wSteve Photographic Technique 4 11-09-2008 09:35 PM
K10D Spot on some images. Help Please. maxamillion Pentax DSLR Discussion 7 12-11-2007 04:01 AM
All times are GMT -7. The time now is 06:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
