12-08-2014, 05:09 AM   #1
Inexpensive External Microphone
I'm searching for a reasonably priced external microphone for recording wildlife sounds. The Rode VideoMic Pro is a little pricier than I'd like. In looking around online I've found that the Sony ECM MSD1 is a available a good deal less, with used ones at under $100. It looks like an acceptable compromise, but I've read conflicting reports about whether the mount is compatible with non-Sony cameras.
Does anyone have experience with this microphone?
Thanks.
12-08-2014, 12:44 PM   #2
Also wondering about this one:
TASCAM TM-2X - X-Y Pattern Stereo Cardioid Mic
Hope someone can help out.
12-08-2014, 01:52 PM   #3
I have the sony.
It's certainly not bad, but i am unsure whether this is suitable for wildlife sounds. Indeed, mine has a sony "minolta" mount. guess adapters are out there, but still..
I think I'd be more confident in the Tascam to be honest.
However, for quality wildlife sounds, you might want to consider a separate handheld recorder?
12-08-2014, 05:02 PM   #4
Thanks! I went ahead and ordered the Tascam (seller has a 30 day return policy). Since weight, size, and ability to get it running fast are factors, this seemed like the best option. I'll test it locally before taking it out.
QuoteOriginally posted by grispie Quote
I have the sony.
12-08-2014, 06:41 PM   #5
QuoteOriginally posted by MarkProjectCoyoteIBW Quote
I have had the Tascam for about a year, you will not be sorry you bought it. It is simply excellent outdoors. One bit of advice get a 2"x4"x3" piece of light (open bubble space) foam rubber pad ,cut and hollow out the center and attach this to the mic for wind noise reduction.
camera, dslr, microphone, photography
K-5 External Microphone Consideration pento57mm Video and Pentax HDSLRs 3 06-29-2014 09:21 AM
External microphone for K-3 Grokh Pentax K-3 4 01-11-2014 02:50 PM
External video microphone suggestions Rottie*Lover Pentax K-01 3 12-03-2012 06:08 AM
External microphone on K7 RobG Pentax DSLR Discussion 19 04-20-2010 06:18 AM
Video / external Microphone suggestions? laissezfaire General Talk 2 09-12-2008 08:38 PM
All times are GMT -7. The time now is 08:56 PM. | See also: NikonForums.com, part of our network of photo forums!
