Originally posted by stevebrot You don't need CIF for flocks of birds. Regular AF or manual focus at or near to infinity and moderate aperture should work just fine. Where it is useful is for macro of bugs moving towards you and other situations where the subject is approaching the camera and focus is hard to time. Note that the time lag to shutter release may result in the actual focus point being somewhat behind what you intend.
Correct. It will be too slow in response. Things happen too fast for the camera to respond.
See if the OP can look at my other method which to me yielded better result.
Geeses landing (2 series) - Steve's Digicams Forums There are suggested setting you can make.
Gulls reflection - Steve's Digicams Forums
Daniel
---------- Post added 12-18-2014 at 05:39 PM ----------
Originally posted by wtlwdwgn Practice, practice, and more practice.
Do it in a predictable and easy way first.
Setting: Manual focus on manual lens, set distance at around 100 ft to a quiet street where car will pass through around 70 ft. On a bright day F8 asa 800 1/1000 - 1/1500 second.
When a car comes in, fire in burst right away and turn your focus dial so you are in focus. The first first 1-2 second will be completely off. But you will get better focus the third second until the car is gone out of sight.
When you have perfected the set up, try to shoot gulls which are every where.
Good luck
Daniel
