Originally posted by sharpshoota I have the K10D and unfortunately I have only the AF-500 flash which I don't beleive is fully compatible. What mode do I actually put the camera in to shoot. I will be shooting important graduation pics in a dimly lit restuarant and need help. Thanks.
ALso, what mode to put the flash in
after owning the 500 since chritmas, I found out the hard way that the most important thing is.....
1) for some reason it functions best if I turn on my K10 first, place the flash on the shoe turned off, then turn it on.
2) make sure that the flash unit lines up EXACTLY in the right place on top of the k10 shoe.
update your firmware on the K10
here is what I do...
make sure the flash is in default.... meaning no adjusting it. zoom your lens a few times to make sure that the zoom on the flash equals the zoom of the lens (if it is in fact a zoom lens) sometimes you need to push your shutter button half way down to start the zoom motor of the flash.
If the 500 doesn't make the "zoom" sound, then very lightly wiggle it on top of the shoe and try again, once the zoom is in sync with the lens zoom, you should get good results with your flash photos. I put the k10's pop up flash on manual and leave the setting on auto (flash on and auto)
one thing I noticed that if you leave the k10 on auto program mode, and the 500 on auto as well, the k10 tends to choose a high ISO in order to make the most of the ambient light in the room.
if you want a clearer shot with less noise, make sure you set the k10 to a lower ISO. A lot of time ISO 400 gives a good balance between sharpness, noise and ambient light mix.
I just bought the lightsphere after a few tries with home made. the home made versions work fine, but the lightsphere has a more professional look to it that goes a long way towards the "image" needed if you want to sell a shot or two to events like our daughter's cheerleading.
it also seems to have the edge on quality of light as well. I got the clear version, and if I want more difusion, I add something like wax paper inside.
so far I have tried the above situations and the photos have been fairly conistantly lit.
I also tried the wireless flash mode with the K10 and the 500 and if you follow the instructions closely, it works excellent.
can't help you on all the other features of the 500 as I am not that far advanced
