12-30-2014, 11:56 AM   #1
Air venting from viewfinder K3
I get a lot of air coming out of my viewfinder when zooming out on my K3. I had the same 18-135 lens on my K5 and never noticed this. I figure the air must vent somewhere but i cant say I like the idea of the air being pulled in and out of the pentaprism area. Sound like dirty trouble down the road.
12-30-2014, 12:07 PM   #2
It has been reported several times and people say that you should not worry about it.
12-30-2014, 12:13 PM   #3
Docrwm's Avatar
It's a weather sealed camera and lens combination so the air inside the lens when extended has to go someplace. Coming out the viewfinder, when all seals are intact, is probably the best place possible all things considered. Try opening one of the rubber covers (like on the mic or other concealed connector) and see if the airflow stops. If so, its the weather sealing doing its job.
12-30-2014, 12:19 PM   #4
K57XR's Avatar
My K5/18-135 does the same thing except the air moves on the side where the USB port is. I'm not sure if other users with the same body/lens combo noticed it by you can actually feel the zoom ring resistance change depending on if the rubber cover is on or off.
12-30-2014, 12:44 PM   #5
Ya if i pull open the USB flapper the air goes in and out there instead. The lens also moves easier too. I just think going out the viewfinder may lead to more dust in the visibility area.
12-30-2014, 12:46 PM   #6
Docrwm's Avatar
QuoteOriginally posted by no694terry Quote
Could be, but its a factor of the WR nature of your setup. You could leave the port open if it bothers you thereby minimizing the dust in the viewfinder.
12-30-2014, 02:27 PM   #7
on mine, it comes out the side of the lens close to the mount. there may be a dust filter at that point, if it is stopped up it will pressurize the camera and can damage the seal integrity. If dust can get in, water can get in. This is the reason I think it is a bad design and I do not like this type of WR lens. The zoom and focus both should be internal. Only the focus and zooming controls should be external.
air, camera, dslr, k3, photography, viewfinder
Pentax k3 air felt through the viewfinder when zooming... TheDude1363 Troubleshooting and Beginner Help 8 12-18-2014 10:41 AM
Travel Playa Tamarindo from Air stanzhou Post Your Photos! 3 11-07-2014 02:03 AM
K3 viewfinder / focusing screen(s) vonBaloney Pentax K-3 4 10-12-2013 10:09 AM
Landscape Lightning from the air ranmar850 Post Your Photos! 3 01-23-2013 08:37 AM
Venting........ janstew Pentax DSLR Discussion 32 02-09-2012 12:26 PM
All times are GMT -7. The time now is 06:07 AM. | See also: NikonForums.com, part of our network of photo forums!
