Originally posted by drevilsmom I inheritied my father's old Pentax Model S1 (I think that's the model) along with three lenses, a 2X teleconverter, and several filters. The lenses are in excellent shape. I currently own a Canon Powershot S1 IS that I have outgrown, and so I am in the market for a DSLR. I really was leaning hard for a Canon XTI, as I am familiar with the Canon setups, but after doing some research AND contacting Pentax, I found out that with an adapter, my father's lenses can be used, albeit only manually. So, it seems like the equivalent to the XTI is the K200D. Have any of you used old glass on the new digitals, and is it worth it? How does the K200D compare to the XTI? Thanks bunches. Oh, and eventually I want to get involved with macro, so does the 100mm macro do macrophotography justice?
Elizabeth
Elizabeth
There are many on the forum who use screw mounts lenses and love them. Personaly, I don't onw any but I do own 8 Manual focus K mount lenses, 7 primes and 1 zoom.
The only things I would caution you about are the following.
- You should consider getting a split image focusing screen to assist in manual focus. Some people comment they find focusing difficult, although that has never been an issue with me.
- metering can sometimes be a little inconsistent with the older lenses, requiring you to take your time, check the histograms, and perhaps do some "characterization tests", to understand how each lens meters with the camera you select.
- with screw mount lenses, you would focus with the lens wide open, and then manually stop the lens down before shooting and set your exposure. Stopping down before focusing is not recommended because the fiewfinder will get dark.
The big advantage you will have is that you already have some lenses, and can play a little to find out what kind of photography interests you the most, without having to go out and get a whole bunch of lenses rioght away.
If you decide pentax (and we all hope you do) then you should go for a lens that compliments those you already have access to. i.e. is wider than what you already have.
