01-10-2015, 08:05 AM   #1
ClinchShots's Avatar
how do you select ISO between 1600-3200 on the K3
I see many photos where artists have their astro photos at 2000 iso but when I try to adjust my k3 there it jumps from 1600 to 3200
I wanted to try and mimic some of their settings
how do I accomplish this?
thanks in advance
01-10-2015, 08:20 AM - 1 Like   #2
Custom menu 1 option1 and option 2
Under option 1 make sure it says 1/3 EV steps. Under option 2 make sure its 'as EV steps'
01-10-2015, 08:20 AM - 1 Like   #3
QuoteOriginally posted by ClinchShots Quote
thanks in advance
Find the menu item called "sensitivity steps" (at least that is what it is called on the K-5) and set it to "as EV steps". That will get you more choices. And you can also set an adjacent menu item "EV steps" to 1/3 instead of 1/2 for even more. (I think with EV steps set to 1/2 and sensitivity to "as EV", you'll have a choice for ISO 2200, but at EV steps 1/3 you'll get 2000.) These settings will also affect the choice of shutter speeds you can choose from.
Some people prefer the 1/2 steps because it allows a 1/180s shutter speed (highest sync speed for flash), whereas at 1/3 steps you can only go to 1/160s. I prefer the 1/3 steps...
01-10-2015, 08:40 AM   #4
Thanks!
camera, dslr, iso, k3, photography, photos
Nature Birding at ISO 1600 - 3200 daacon Post Your Photos! 9 09-27-2015 07:46 AM
Do you turn your K3 off between shots? sadatoni Pentax K-3 & K-3 II 16 10-28-2014 05:20 AM
Salt spray on the beach. How do you handle that? maxxxx Pentax DSLR Discussion 6 08-17-2014 04:07 PM
How do you avoid filters getting stuck on the lens? maxxxx Pentax SLR Lens Discussion 14 06-21-2014 01:31 PM
How ISO 3200+ works on your K-5 [technical] secateurs Pentax K-5 & K-5 II 33 10-27-2010 12:28 AM
All times are GMT -7. The time now is 09:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
