01-16-2015, 12:53 PM   #1
Will AF.C Cause Undo Wear on my K5?
Just curious if keeping the Auto Focus set to "Constant" is asking for trouble down the road. I never had my K10D set to constant, but recently read about having it set to constant in order to capture the image in correct focus using the back button instead of using a half press on the shutter button.
I expect to have this body for a long time (enthusiast) and don't want to screw myself by using a technique that isn't recommended.
Thanks
01-16-2015, 01:08 PM   #2
It would damage the camera only when you get annoyed enough with the constant AF adjustments and decide to spike your camera like you're in the NFL.
Other than that you're OK.
01-16-2015, 01:13 PM - 2 Likes   #3
It's safe to use AF.C.
I am very happy that I set my K-5 to use the rear AF button. The AF switch can stay in AF.C all the time. Holding the rear AF button gives AF.C. A short press of the button simulates AF.S. No button press with a quickshift lens allows manual focus.
Last edited by DeadJohn; 01-16-2015 at 02:51 PM. Reason: horrible grammar - I'll blame my phone keyboard
01-16-2015, 01:34 PM   #4
QuoteOriginally posted by alamo5000 Quote
I laughed...
---------- Post added 01-16-15 at 02:35 PM ----------
QuoteOriginally posted by DeadJohn Quote
Im very happy camera that I set my K-5 to use the rear AF button. The AF switch stays in AF.C all the time. Hold rear AF down gives AF.C. A short press of rear AF simulates AF.S. No button press with a quickshift lens allows manual focus.
Thanks
01-16-2015, 02:08 PM   #5
6BQ5's Avatar
You'll be OK. It just drains the battery a bit since the motor is constantly torquing. Honestly, your shutter and mirror assembly will probably bonk out on you before anything else does.
01-16-2015, 02:59 PM   #6
Electrical motors are, thankfully, very old technology and are very reliable, so the failure won't be a limiting factor for you. It also should be a relatively cheap fix.
af, af adjustments, af.c, af.c cause, button, camera, dslr, focus, photography, press
remote will not work on my K5 Pete C Troubleshooting and Beginner Help 7 12-23-2013 02:49 PM
Will this lens work with my K5? mcook Pentax SLR Lens Discussion 14 05-15-2013 10:53 AM
My observation on K5 AF issue hyyz Pentax K-5 9 01-14-2013 08:11 PM
Lens compatibility confirmation: Will my MZ-30 lenses work on K5 or K5 II? RachaelJamess Visitors' Center 4 11-22-2012 10:23 AM
K5 af.c billy moon Pentax K-5 10 08-27-2011 08:07 AM
All times are GMT -7. The time now is 04:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
