Originally posted by gord lucas What I want in a Pentax (or any other) flagship camera. A fully manual, match-needle DSLR of minimum 30MP, no modes, no flash, no frills - just a shutter, aperture, top-notch sensor, minimalist menu, on/off switch autofocus with only a central focussing dot, absolutely solid, a DSLR version of a Topcon RE Super or an Alpa. Don't care if it's a Cmos or full sensor. Just the most basic, beautiful, and toughest camera ever made. Weather sealing would be the icing on the cake.
Dream on, Gord, dream on.
Does ANYONE else out there even sympathize, or am I alone??
Not quite.
I want:
* match-needle APS-C DSLR
* centre-weighted metering and spot metering only
* modern, ergonomic grip
* available battery/portrait grip
* Dual SD slots with % full readout
* control wheels with built-in setting displays for aperture, shutter and ISO, and clicking/detent ability to feel 1/3 stop adjustments
* minimum 14 MP
* minimum 14 Ev Dynamic Range, 3200 ISO low light, 25 bit colour score on DXOMark
* DNG only
* single shot mode only. No bracketing, no continuous shooting
* 1.0x equivalent magnification, 120% coverage viewfinder (using a magnifying prism, and a mirror that reflects more than what the APS-C sensor can see. Some vignetting in the viewfinder outside the 100% range with some APS-C lenses)
* shock, dust, moisture and temperature resistant from -30 to +50 degrees Celsius
* Shake Reduction and sensor cleaning function
* sleep function
* cold boot in less than 50 ms
* power off in less than 50 ms
* less than 50 ms shutter lag
* subdued, modern styling
* comes with case made of natural materials resistant to mould and fungus
* non-slip strap included, works with lenses weighing up to 1 kg, fits in case
* the kit lens is the 31mm f1.8 but without the "Limited" marking, smaller, without autofocus
* standard tripod interface as usual
* made in Canada, in a carbon-neutral facility
To the people who always say "it's just as expensive, you still need a big CPU, etc": here is what would
not be required:
* large buffer
* sensor with live view capability or fast readout
* autofocus sensor (since I did not ask for a focus dot)
* sophisticated mirror (since there is no autofocus sensor below, and no fps requirement)
* dim screen (since there is no autofocus)
* plugs or jacks or hotshoes for flash or HDMI or USB
* electronic displays such as top or rear LCD
* JPEG engine, white balance controls, contrast controls, on-board defishing or filleting, etc
* speaker for sound effects
* delete, play, or arrow buttons, since there is no review
* exposure compensation, since there is a needle
* flash
* interoperability with any devices other than lenses and SD cards
* complicated CPU
* software bundle
* user manual
* being the "digital equivalent" of anything in particular
To the people who always say "get a Leica": this has the following advantages over a Leica:
* it is not a piece of jewellery, nor is it a showpiece, nor does it masterfully balance form and function
* the average person can learn to use the viewfinder to compose and focus very easily and accurately
* it does not have a $1000 red dot
* it works with Pentax lenses :-P
* did you read the feature set?
