Originally posted by Truax_photo Hi All,
I want to get a feel from those of you that have experience with these lenses... Which lense, in your opinion, is the best for portraits & wedding shoots?
40mm limited pancake, 70mm pancake, FA 50mm 1.4, FA 50mm 1.7
I currently am using the Tamron 28-75 Xr Di 2.8..... I really want to get to pentax glass and would like to try using the primes....Any other thoughts are welcomed also...
Thanks!
It really depends on the type of photographer that YOU are. The truth is that you can create spectacular portraits and wedding photos with ANY of these lenses ... including the Tamron 28-75 2.8 that you already own.
In general, from the lenses that you've already mentioned, the DA70 makes the most sense as a "portrait" lens because of reduced distortion and a good working distance. The DA40 makes more sense as a wedding candid lens because it's wide enough to get two people in the frame for quick candids.
I used to use the FA50 quite often, but now I use the DA70 and DA40 because they're sharper and less prone to CA and PF.
In practical terms, unless you're shooting 100 percent posed/formal shots at a wedding you'll have a hard time matching the flexibility of a constant-aperture zoom lens at a wedding. Candid (pre-ceremony and reception) and ceremony shots involve people who are constantly moving around, and your clients will expect you to capture those once-in-a-lifetime moments as they happen. You can't stop and change lenses most of the time without missing an important moment.
I take three DSLR bodies with me to every wedding (two K10D bodies and one DL) One body has a Sigma 24-70mm f2.8 zoom, the other two have prime lenses (usually a DA40, DA70, FA135 or a DA200).
The camera with the Sigma 24-70 is my "primary shooter," the one with the DA40 or DA70 is my "low light" shooter set to ISO 800 or 1600 by default, and the other body stays mounted to a tripod with the 135 or 200.
