Originally posted by Woodepic I have hear rumours that we can trick our camera's shake reduction into an improvised tilt-shift, by making the sensor tilt, and shift. I have heard the the sensor can move a total of 8mm?
The manual claims 1.5mm shift up, down, left, or right, but this is restricted to 1mm if you've also rotated the sensor. It can be rotated 1 degree either way (axis of rotation = lens axis). No tilting any way, or moving the sensor backwards in time (it's already moving forward in time at a non-user adjustable rate).
No replacement for a proper lens, but not too shabby as an included feature you can use with any lens you mount.
