I have two original Pentax M42-K adapters, which I rarely use. I mounted cheap adapters on each M42 lens, of course after I removed the spring. I recently bought a black M42-K adapter without spring from factory (double price compared to cheapest adapters). I had no problems so far, not fell any lens with these permanent cheap adapters on the lens. The main problem, for me, is the alignment marks (aperture, focus) on the lens. For cheap adapters, each has a different alignment, they are not two similar. For one the the lens inscriptions are offset by about 180 degrees!. Original adapters allow correct alignment, but for me it is uncomfortable changing lenses in this way. Too long 5 seconds
, I exchange bayonet lenses in 0.5 seconds
