02-22-2015, 03:57 PM   #1
My K3 locked up with pink artifacts can't turn off/on
My K3 locked up with pink artifacts while shooting at an event. I wasted 10 mins on k3 trying to fix this problem. I was using battery grip with 2 batteries. Samsung pro SD card 90MB/S (been using this setup for over 4 months without problem). The only way to fix this problem was to remove the in body battery. The battery selected was on AUTO. After switching battery to use body only, the problem was fixed. I will post a picture when it happen again. This is the first time having this problem.
02-22-2015, 04:07 PM   #2
Was one of the two batteries running low? That can increase the likelihood of freezing up.
02-22-2015, 04:18 PM   #3
Scorpio71GR's Avatar
I have never set the battery setting to auto. I always use grip first that way I do not have to remove the grip to take out the first dead battery. Most of the time I will switch the battery myself manually before it goes dead to avoid problems.
02-22-2015, 04:24 PM   #4
Nope, it wasn't even half way. nothing work unless I remove grip and the body battery.
02-22-2015, 05:21 PM - 1 Like   #5
JayBee451's Avatar
My K3 froze up the other day also, but I did not have the grip attached at the time.
It happened as I wanted to show some friends a few images I had taken.
Battery had over half charge left, nothing worked, no response from anything I did.
Removed battery, re install and all was OK again.
This has been a one of so far.
artifacts, battery, body, camera, dslr, k3, photography
Turn off auto focus on K3 Shutter Button Mark K5 Troubleshooting and Beginner Help 7 03-02-2015 01:30 PM
Do you turn your K3 off between shots? sadatoni Pentax K-3 16 10-28-2014 05:20 AM
K3 Focus confirmation beep - can I turn it off? Molly Troubleshooting and Beginner Help 6 07-31-2014 09:24 AM
shake reduction can't turn on ? davidsyd Pentax K-30 & K-50 3 12-24-2012 07:32 AM
Mirror up, camera won't turn on clickinchick Troubleshooting and Beginner Help 3 01-26-2011 07:20 PM
All times are GMT -7. The time now is 01:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
