03-02-2015, 12:47 AM   #16
That's not so simple. Imagine a location with outdoors shots, there is the sun, then the clouds come, then indoors in 'yellow' hall, then you go to the 'blue' or whatever ballroom, then they dim the ligts, etc.
Shoot in DNG, shoot a gray card before you start. When you are back on the computer, one click to set the WB from the gray card, synchronize that to all images from the shoot. Done. Literally 30 seconds to set WB for 1,000 images.
03-02-2015, 09:26 AM   #17
jatrax's Avatar
QuoteOriginally posted by Prakticant Quote
That's what AWB is for. If you set up in a reception hall or church or business lobby, shoot a gray card because the light mix in that location will not change. If you are shooting portraits on site make sure the gray card is in the spot the subject will be sitting / standing in. In office buildings they often replace bulbs with new ones that are not the same as the original so the light mix can be weird.
You should be shooting your gray cards on location prior to the shoot during your preliminary visit anyway.
Outside just use AWB, on the k-3 it is quite accurate in most situations.
03-02-2015, 02:40 PM   #18
True. The K-3's 86,000 pixel light metering sensor is pretty good at helping the camera figure out WB. However even when shooting outdoors (especially in the evening or under event lighting), I still periodically shoot a grey card as I move around, as a reference point for any necessary Lightroom WB tuning.
03-02-2015, 02:45 PM   #19
jatrax's Avatar
Agree, better safe than sorry if you can. If the light looks funky, shoot a gray card. Doesn't hurt anything. I have a gray sling bag I often use. It's not perfect but it is quick.
03-02-2015, 03:57 PM   #20
Indeed. As good as the AWB usually is, there are still may instances (eg the colour of light in the shadows at night events) where the WB can be particularly tricky. So sometimes a grey card can save the day.
balance, button, camera, card, click, copy, course, dslr, images, info on youtube, k3, k5, layers, lightroom, photography, post, time, wb, youtube, youtube etc/need
Capture One won't support 645z.. I need your help 645z Pentax Medium Format 10 10-20-2014 01:26 PM
Need help understanding mirrorless blackout jon404 Pentax K-01 3 04-01-2013 11:19 PM
Can't find much info on this camera: Ricoh XR7 Lulerfly Pentax Film SLR Discussion 54 02-19-2011 01:35 PM
Wedding & Portrait Photogs - I Need Your Help edolyne Pentax DSLR Discussion 15 01-06-2010 01:02 PM
Why can't I find any info on this lens? magnum1 Pentax SLR Lens Discussion 3 12-17-2007 04:49 PM
All times are GMT -7. The time now is 04:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
