Originally posted by Adam The way the interval is set up is a little bit confusing. For example, if you wanted to shoot photos at a shutter speed of 2s each 5s apart, you would need to use an interval of 7s (2+5), since the interval does not stack on top of the shutter speed.
I don't understand how that would make a difference? Are you saying that for example I started out shooting at 2s exposure on 2s intervals in AV mode and then as it gets darker the exposure is 10s the camera is missing out on those extra 2 exposures? (2+2=4 / 2+10=12 4/12=3). It still wouldn't add up though as its random every time because I just restart it when it stops.
What i think is happening is that the software fix for the runaway shutter is doing its job by not making the shutter go crazy, but it seems to be stopping my intervals? That would explain the randomness of the frames its shooting.
---------- Post added 02-27-15 at 01:04 AM ----------
Originally posted by Korus I don't understand how that would make a difference? Are you saying that for example I started out shooting at 2s exposure on 2s intervals in AV mode and then as it gets darker the exposure is 10s the camera is missing out on those extra 2 exposures? (2+2=4 / 2+10=12 4/12=3). It still wouldn't add up though as its random every time because I just restart it when it stops.
For instance when I was out tonight it happened the first time after 113 shots, second time 100 and the third time 48. Exposure time started at 2s and went to 8s over a few hours, interval time was 4s. Overall shot number was set at 500.
If intervals don't stack on top of the shutter speed then in makes AV mode pretty much unusable, unless off course I set the intervals to the maximum exposure/interval combo of 1 min per interval (30s Exp / 30s Int). You can obviously go longer on the exposures with bulb, but I'm not really at the level yet and I don't think I'll be giving it a shot anytime soon if thats the case with the K3.
Hopefully thats not the case but I see you have over 30k posts so I'm guessing you know Pentax inside out by now
