Eneloops do age. A quality 'smart' battery charger that charges cells individually can help prolong their life and even refresh tired ones. Once their performance sagged below my frustration limit in my k100d, that set of eneloops was relegated to flash duty (where 8 year old sets continue to shine
). I found the high capacity XX eneloops a step up from the usual white ones for k100d use, but moved to a k5iis shortly after my first XX set and the battery life with it's lithium pack is just so much better..
Originally posted by peggers Here is another question. Is it possible that with shake reduction engaged, the shots are actually not quite as sharp as when shake reduction is not turned on? Seems counter intuitive, but I have noticed it from time to time. Could just be coincidence of course.
Make sure the SR has spooled up properly (green hand has lit up before you fire). It is recorded in the exif. In any case, SR is never a guarantee of a sharp shot but if it's troubling, you might want to try testing it under more controlled conditions.
