03-16-2015, 06:50 AM   #1
igabc's Avatar
SR not enabled on K3
Why the shake reduction function no my K3 is always greyed out with vintage lenses?
Thanks
03-16-2015, 07:03 AM   #2
pete-tarmigan's Avatar
QuoteOriginally posted by igabc Quote
Thanks
See the K-3 Operating Manual, p. 82.
03-16-2015, 08:58 AM   #3
The SR function can only operate if the camera knows the focal length of the lens. Since vintage lenses cannot communicate with the camera body, you must manually input the focal length.
03-16-2015, 09:04 AM   #4
igabc's Avatar
That's what I always do. No success
03-16-2015, 09:19 AM   #5
Are you shooting with the 2s or 10s timer? If this is the case the SR will be forced off no matter what lens is mounted in the camera.
03-16-2015, 09:32 AM   #6
igabc's Avatar
No it's not on timer
03-16-2015, 10:24 AM   #7
jatrax's Avatar
Are you using the remote setting in the drive mode? That also turns off SR.
To test, change the lens to a modern one with contacts and see if it works there. Once it works with that lens then you know it is the lens and not the camera settings.
One other possibility is if the manual lens has a non-conductive mount. The camera cannot detect the lens. Do you get a prompt to select focal length on startup or are you selecting it manually? If you don't get the prompt it is an indication that the camera cannot see the lens and even if you input the focal length the camera still thinks there is no lens attached.
03-16-2015, 11:44 AM   #8
Do you have "Using Aperture Ring" set to "Enable"? ( Menu C4 item 27, page 83 in the manual).
If you are using lenses with an aperture ring with no "A" setting (or set in a position other than "A") then you have to enable use of the aperture ring.
03-16-2015, 06:17 PM   #9
igabc's Avatar
1. No remote
2. Using a lens with A auto lens. I actually tried with 3 vintage A lenses and none was working.
Now it's all good again. Can't figure out what was wrong.
I'll post if I'll spot the problem.
thank you
camera, dslr, k3, photography
K3 sr tennjed Pentax K-3 8 03-02-2015 06:53 PM
Pentax k3 live-view noise jerk normal? Tested SR on and off... NW_Legacy Pentax DSLR Discussion 2 02-12-2015 10:28 PM
Sigma EF-610 Super not firing on K3 iikamrii Troubleshooting and Beginner Help 3 06-13-2014 06:52 PM
New model sigma 18-250 lens not focussing correctly on k3 David&karen Pentax SLR Lens Discussion 2 05-16-2014 08:02 AM
digital SR in k3 paranoia23 Video and Pentax HDSLRs 14 12-01-2013 06:31 AM
All times are GMT -7. The time now is 09:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
