Originally posted by Clavius ISO 100/200/400 images look practically the same with excellent detail, colors and, as expected, extremely little to zero noise, and therefore all print up to a maximum size of 24 x 36 inches. At this resolution, we are pushing the limits of the 12MP full-frame sensor, and at close inspection, you can see some pixelation. However at normal viewing distances of an arm-length or further, images look nice and crisp.
But this you can say from any DSLR really including a K10D... I mean I have no noise, I have more details and I have great colors on my K3. Technical tests show that the A7S perform better at high iso than my K3, mostly due from sensor size, a bit from their different photosite design, a bit from their reduced photosite density. For the rest, it is no better than the K3 and has less resolution than a K3. For dynamic range and color deph, this A7S get lower results than the other typical Sony sensor included a good old K5.
One can say we don't need that. After all Canon has only 12 EV worth of dynamic range on their sensor instead of the 14+ you can get from Nikon/Pentax.
This is just to say that the Sony A7s is really a compromise and that you loose technically more than what you gain: bit better high iso, half the pixel, a low pass filter, less dynamic range and less color deph. This is a specialized camera.
Even I know many dislike to admit that, the high pixel count camera are the best compromize we have right now because the pixel density has almost no impact on different sensor figures as the key concept is more the whole sensor area than the number of pixel it has.
If high iso performance is the most critical for you, you'll find yourself with a more interresting camera with a 645Z even through it has 51MP.
I highly suspect it was not tested by DxO uppon request of some competitors. It would hurt them to have the #1 ranking on every category camera to be a Pentax.
