02-03-2007, 01:34 PM   #1
K110D flash
is there any way to make the flash on the camera less bright?
thanks,
Amanda
02-03-2007, 01:53 PM   #2
there is a menu setting to turn it down.. when in P mode a minus ev will also turn it down..
trog
02-03-2007, 01:54 PM   #3
Buddha Jones's Avatar
Not that I know of, but you can always adjust the aperature settings +/-
02-03-2007, 01:54 PM   #4
QuoteOriginally posted by trog100 Quote
trog
Kneel before Trog!
02-03-2007, 08:04 PM   #5
Alvin's Avatar
Amanda,
Press Menu. Under "Rec. Mode" tab, find "Flash Exp. Comp." by going up or down, then press ">".
Negative numbers will bring down the flash power, Positive will strengthen it.
Cheers!
02-04-2007, 06:13 PM   #6
thank you
Amanda
camera, dslr, flash, photography
Flash for Pentax ist k110d ppaul_l Troubleshooting and Beginner Help 13 03-28-2011 04:29 AM
K110D + AF540FGZ, limited auto flash? MEtoK110D Pentax DSLR Discussion 4 10-27-2009 01:57 AM
External flash for K110D Panache Pentax DSLR Discussion 13 11-12-2008 06:22 AM
Does the AF 240 FT flash work with K110D ? tasha_22 Flashes, Lighting, and Studio 7 07-03-2007 10:41 AM
K110D/flash voltage khardur Pentax DSLR Discussion 1 05-13-2007 05:37 PM
All times are GMT -7. The time now is 12:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
