06-05-2008, 11:26 AM   #1
ariahspam's Avatar
K20D problem
Hi, I've got a problem with the camera. It has happened 4 times. The problem is:
When I shot and then press the 'play' button to see the picture, nothing appears and the buttons stop working. When I turn the camera off, the number of remaining pictures is displayed on the top lcd. If the camera is then turned on, the buttons still don't work, if turned off, the remaining pics still displayed. I have to manually take off the battery and insert it again to fix this. I'm using a 1-month old transcend 8gb class 6. I tend to format the card on-camera instead of deleting the pictures via PC.
Any comments? Has this happened to any of you?
06-05-2008, 11:52 AM   #2
Wheatfield's Avatar
Are you making certain the write light is off before you start pushing buttons? I just bought a few Patriot 8gb class 6 cards (probably the same as your Transcends with different labels) and find they are very slow to write to.
06-05-2008, 01:38 PM   #3
ftpaddict's Avatar
QuoteOriginally posted by ariahspam Quote
When I turn the camera off, the number of remaining pictures is displayed on the top lcd...
That's actually supposed to happen.
06-05-2008, 07:39 PM   #4
ariahspam's Avatar
QuoteOriginally posted by ftpaddict Quote
Sorry, forgot to mention the fact that the shot taken is lost.
06-05-2008, 11:13 PM   #5
Jaleel's Avatar
Maybe a SD card problem
Try another card to see if this a camera problem or card
06-06-2008, 12:23 AM   #6
ftpaddict's Avatar
It's a K20D, so I'm sure it's still under warranty. If swapping SDs doesn't work, it's off to get it serviced.
06-06-2008, 12:10 PM   #7
ariahspam's Avatar
Well, unfortunately it is nearly impossible to send equipment for the warranty as I live in south america and, memory cards here are very expensive so I'll just have to wait to buy another one. Thanks anyway
buttons, camera, dslr, photography, pictures
k20d problem Neto Pentax DSLR Discussion 2 09-24-2009 02:59 AM
K20D Problem photoTaz Pentax DSLR Discussion 2 06-21-2009 09:25 PM
Just got my K20D... problem already - need help! dimak Troubleshooting and Beginner Help 6 05-01-2009 04:21 AM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
Problem with K20D eadnams Pentax DSLR Discussion 7 06-28-2008 07:21 AM
All times are GMT -7. The time now is 04:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
