Originally posted by Thingo The sensitivity mode, Sv, is separate from the rest, however, and the ISO set here is maintained until you next use that mode.
See the second paragraph of my earlier post
here.
I've never used Sv before, thanks for pointing out. But I don't thing it would help me much in this case, since I wouldn't have any control over aperture and speed. I might still check is the camera automatically select the widest aperture if I set Program Line "Hi speed priority", in that case it would be a good workaround for this particular situation.
---------- Post added 04-07-15 at 11:23 AM ----------
Originally posted by calsan This also annoyed me until I "discovered" TAV mode!
In my case, while it would have the advantage of not using the program dial, it would still be a lot of messing with settings. I'm looking for a way to just have the settings stored and not changing them each time: maybe the Sv program trick might work.
While I understand that the K7 is a quite old model at the moment and no more support is to be expected, since i't just a software setting, it would have been extremely easy to let the user choose from the menu if they wanted to store Iso settings globally or for each separate program. I don't know if this was implemented in the newer models.
